Replacing Fuel Solenoid on 1520
   / Replacing Fuel Solenoid on 1520 #1
traded
NY
John Deere 1520; John Deere 5420
Good Day all, I own a John Deere 1520 and am looking for a replacement for my fuel shutoff solenoid due to leakage. The solenoid is on a Marvel Schebler carburetor. The replacement solenoid is currently quite costly and I would rather not spend if there is possibly some other sort of alternative. Any and all help is greatly appreciated.
   / Replacing Fuel Solenoid on 1520 #2
Older John Deeres had a manual fuel shut off on the carb. It was like a needle valve with a T handle you manually opened and closed. I am thinking maybe a 2010 gas tractor had one. Parts guy may be able to find you one with some searching.
   / Replacing Fuel Solenoid on 1520 #3
Here's manual valve for some gasoline carb. RE19406 Screw - JET ADJUSTMENT ASSEMBLY ADD 20.97 USD
Thank you very much, I'll have to purchase one and see how she works!
   / Replacing Fuel Solenoid on 1520 #5
TxJim, I believe the adjuster screw/solenoid replacement you listed actually fits the Zenith carburetor. I don't think it will fit the Marvel Schebler. The correct number should be AT14476 adjuster. Unfortunately it is more expensive at $77.09. Still much better than replacement solenoid AR67706 at $300.00.
   / Replacing Fuel Solenoid on 1520 #6
Danged old age & lack of good reader comprehension. Thanks for correction.
Ok so I'm looking for the AT14476 thank you very much greatly appreciated!
When I search that part number is comes up as a seat? Is this number correct?
   / Replacing Fuel Solenoid on 1520 #9
This is from JDparts.com AT14476 Seat - SEAT AND NEEDLE ADD 77.09 USD
Thank you guys heading out today to see if I can pick one up will let you know how I make out!
MASSEY FERGUSON  670 (A48992)
MASSEY FERGUSON...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A50458)
2013 CATERPILLAR...
2014 Big Tex 12ft. S/A Utility Trailer (A48082)
2014 Big Tex 12ft...
2010 HEIL TOKEN TRAILER (A48992)
2010 HEIL TOKEN...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2008 CATERPILLAR CB434D DBL DRUM ROLLER (A50458)
2008 CATERPILLAR...
