Replacing rubber boot on the front shaft
   / Replacing rubber boot on the front shaft #1
sonofczechgun
Old Dominion
B1750HST 4WD
greetings. I got a new boot for the front shaft from Tractorsmart but I can not figure out how to replace it.
I have to disconnect the shaft somewhere, but all the u-joints seem to be pressed on. Any idea anybody?
Thank you
Oh, it is for B1750 4x4 with HDST, thanks
   / Replacing rubber boot on the front shaft #2
Which front shaft are you referring too? /forums/images/graemlins/confused.gif
Front drive Shaft?
Front steering?
sorry, front drive shaft.
   / Replacing rubber boot on the front shaft #4
When you slide the cover back you should see the U-joint. There should be split pin(s) (roll pins) holding the U-joint assembly on the input shaft of the front axle. Remove the pins and shaft should slide off. I am looking at a B24-27-2910 WSM. I believe they are similar to your 1750. Rear or transmission end should have similar pins.
1994 21ft. Aquasport 210 CCP Division Boat with 24ft. Continental T/A Boat Trailer (A55758)
1994 21ft...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
CATERPILLAR 303.5E2 CR EXCAVATOR (A52706)
CATERPILLAR...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
Chevy caprice (A55758)
