Replacing Stock Bed with Dump Bed on Ram 3500
   / Replacing Stock Bed with Dump Bed on Ram 3500 #11
One thing you may run into...
The dually pickup rear axle is often wider than the chassis/cab rear axle. This is to allow the inner wheels to fit the standard wheelwell in the bed. If you put a "standard" dump bed on, the wheels will stick out. Not a biggie, but a friend had one like this and it just kind of looks odd. Maybe there is a wider bed option available for the dump? Your local truck upfitter should be able to help.
   / Replacing Stock Bed with Dump Bed on Ram 3500 #12
A dump bed insert would be easier.
Check craigslist
   / Replacing Stock Bed with Dump Bed on Ram 3500 #13
The OP has not posted since April, 2012
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
