Replacing Stock Bed with Dump Bed on Ram 3500
   / Replacing Stock Bed with Dump Bed on Ram 3500 #11
One thing you may run into...
The dually pickup rear axle is often wider than the chassis/cab rear axle. This is to allow the inner wheels to fit the standard wheelwell in the bed. If you put a "standard" dump bed on, the wheels will stick out. Not a biggie, but a friend had one like this and it just kind of looks odd. Maybe there is a wider bed option available for the dump? Your local truck upfitter should be able to help.
   / Replacing Stock Bed with Dump Bed on Ram 3500 #12
A dump bed insert would be easier.
Check craigslist
   / Replacing Stock Bed with Dump Bed on Ram 3500 #13
The OP has not posted since April, 2012
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2022 KMC 21-39-HD LOT NUMBER 197 (A53084)
2022 KMC 21-39-HD...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
