Reposting with same problem on NH 1715
   / Reposting with same problem on NH 1715 #11
My mahindra 4035 was doing the same thing the other day, i had to use the manual pump and it started and would run fine until i cut it off, then i would have pump it up again.I could not find where it was getting air until i took the fuel line off between filter and tank and found a pin hole in it. It does not take much air to cause problems. I hope this helps
I am trying to get that info from the mechanic, as I did not write it down. I believe it is on my bill, but I am trying to locate it as my wife has her own filing system and I don't saavy it. Will post it when I get the paper work or hear from the NH shop.
I did replace that line before I took it too the shop. I am looking at the two lines that go into the top of the fuel tank from the injector overflows
   / Reposting with same problem on NH 1715 #14
Does the 1715 have a timer for the glow plugs or do you activate them manually with the key. I seems like the glow plugs aren't staying on long enough.
Bill
2019 INTERNATIONAL LT625 SLEEPER (A59575)
2019 INTERNATIONAL...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56436)
Midwestern...
KBH Tender Trailer (A56436)
KBH Tender Trailer...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
