disney
- Joined
- Aug 11, 2012
- Messages
- 378
- Location
- orlando fl
- Tractor
- scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Hello, and good morning to all! I would like to hear suggestions/ recommendations for rebar spacing (and #4 vs #5) for a driveway extension I will be working on soon for my neighbor (who is like a father). A class A (front engine gas) motor home will have its rear wheels on this new part. I plan on using 4,000 psi 'crete with fiber from the local cement/'crete company. I plan on the slab to be 6" (or the height of a 2x6) thick. (existing slab less than 4", and this is florida, so freezing should not be an issue with current weather trends....) The addition will be about 14' wide and the depth/length will be on an angle (due to existing driveway) from about 5ft to 8ft. All of these dimensions could change slightly, but that is the general size. I would rather spend a little more now, than say "if only I had....", but I would not like to break the bank putting #8 on a six inch grid either.... Thank you in advance to all that offer friendly and/or helpful comments, and advice.
And for what its worth; I have always preferred working with #5 over #4, unless more than a few bends are required, which there should not be any on this.
Also the rebar chairs are at a height of 2&2.5" I would think that should be fine, as I would think it would be better to have the rebar slightly below center, than at (or above) center.
