Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,896
- Tractor
- Kubota BX25
Science Lesson first:
The technology has changed a lot over the last 20 years a lot; due to all the studies and experimentation of the American Concrete Institute (ACI). They are the industry experts and their process and procedures have ANSI recognition and are specified standards in the Building Codes. For slabs on grade the current trend is fibered concrete placed over a compacted structural base (crushed gravel) and no rebar or mesh (glad nobody mentioned that). Compaction of the base rock is the key as it is supporting the slab structurally. A proper base you could have good results with 300 PSI concrete.
Rebar is a must though if your base is not compactable as then you are building a Structural Slab that has to support itself and any imposed loads. A structural slab is an engineered solution where all the variables are considered and a solution designed.
Now to your DIY project:
Do not tie the new slab to the old as that is a "construction joint". It gets a piece of joint material placed between so the new slab is not restrained. As the new slab tries to support the old movement will occur and the old will probably fracture.
The most important part of this job has not been covered: CONTROL JOINTS These are fracture plane place deliberately to tell the new concrete where to crack not where it wants/will. They can be troweled in or saw cut after finishing. They need to be cut 1/3 minimum depth of the slab thickness. If you are using an old timer finisher he will poh poh this and want to use his edging tool to make a fashion statement to keep you happy; but, believe me it is necessary one way or another. Saw cutting has to be done as done right behind the finisher, the next morning is too late, the concrete has already cracked where it wants to.
I would do a control joint every 10-12 feet across the slab.
15 years ago; previous house I lived at we did an 80 foot x 14 foot drive way done in this manner; 4,000#, 5% air, fiber, 6" slump (it was pumped), no water added at site, well dampened crushed gravel base, here in the NW water cured (just beat the rain that day) heavy broom finish as it was a slope. The finisher used the control joint tool I specified. Saw cutting is easier if there are a lot of joints.
Today, No cracks anywhere yet. A year after placing it had a gravel truck and a concrete truck drive over it for a project behind the house; never phased it. I parked my 40 MH on it for 8 years. SUCCESS ? Your call.
