Requesting Clutch Pack for Yanmar FX255D
   / Requesting Clutch Pack for Yanmar FX255D #11
At least on the smaller/earlier Yanmars, the PTO is driven by direct shafts and gears same as a manual transmission, while the Powershift input is (logically) driven off another shaft after the transmission input independent of the PTO. This is why you can let the clutch out to start a tiller etc spinning, then later shift the little Powershift lever from N to 1 to get the tractor moving. Since they are independent, a working PTO will tell you the conventional, automotive clutch up on the flywheel is ok, but a good PTO doesn't imply anything about the Powershift.
If nobody anywhere has experience with a Yanmar Powershift then I think the next alternative is to find a mechanic - probably an old one - experienced in a bench teardown of Japanese automatic transmissions. Long ago, like over 50 years ago, I tore down an Oldsmoble Hydramatic following instructions from a Motor's manual and replaced the clutch elements like what is in this Powershift. Its not magic. What you need here is a mechanic experienced in tracing the hydraulic circuits where a blockage is most likely the problem. And worst case, someone who recognizes that those same clutches are also used in some Japanese car or motorcycle. If so then replacements are available, or maybe similar ones could be cut down to fit. This isn't an impossible problem; you just haven't found the right mechanic.
   / Requesting Clutch Pack for Yanmar FX255D #12
you really need to get that tractor home and follow the advice of normde2001, it is so simple to replace that spring. 3min job. it sits right next to your right foot. it could even have some debris in there. also have you changed your hyd. filter?
   / Requesting Clutch Pack for Yanmar FX255D #13
Excuse my ignorance, as normal I wasn't paying attention and my old mind just went to manual clutch and not power shift.
Good advice has been given.
   / Requesting Clutch Pack for Yanmar FX255D #14
Bottom line, if the pto works, check/replace the relief valve spring, (1/2 hour job), if not, check/adjust/replace the clutch. A tractor mechanic should know this.
   / Requesting Clutch Pack for Yanmar FX255D #15
Once again - listen to Norm. Test the easy and most likely issues first before going off into stuff that is possible but not likely at all.
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
CFG Industrial XZ20R (A50121)
CFG Industrial...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
