Restoring old barn Timbers
   / Restoring old barn Timbers #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
We have torn down two barns that are 90-100 years old and removed as many hand hewed timbers as possible. A couple of them are 21ft long and as new but most are weathered and have minor rot and or bug holes toward the surface. All but 2 are 8x8 oak post and the 2 are 11x11 oak. How might i go about getting these cleaned and ready to use in the interior of a new home construction?
   / Restoring old barn Timbers #2
This is typically done by running them through a planer in order to remove a small amount of material and also to size them consistently.
   / Restoring old barn Timbers #3
Pressure washer or wire wheel on a grinder or wire brush.
Might want to spray them with a Boracare to help prevent further decay and insect damage.
   / Restoring old barn Timbers #4
How will you be using them, as timbers, or will you rip them down into boards?
   / Restoring old barn Timbers #5
If you want the appearance of bright rough sawn lumber, find someone with a good bandsaw sawmill, that is particular about their work. Dad sawed many barn beams for a local building contractor who salvaged old barns. He would saw 3/8" off the outside of the beam, which the contractor used for real wood paneling. The rest was sawn into hardwood flooring.
   / Restoring old barn Timbers #6
Might be able to sand blast them using a very fine medium/powder. Have seen it done for homes in Colorado using walnut or pecan hulls too.
   / Restoring old barn Timbers #7
Try bleach on a piece and see how it comes out after it dries for a day or two. I know a company that bleaches new post and beam houses.
Ive considered plaining them down but problem is they are hand hewed and i really want to keep this appearance as my great grand parents did the work. I see some very small holes in certain areas so figured bugs were or are in there now. I will use these in basement man-cave and 2 for front porch of future new home.
   / Restoring old barn Timbers #9
I don't blame you for wanting to keep the look of the boards. Why not just treat them for bugs...then put a light varnish on them. Would look great on a wall.....just make sure the bugs are gone! Good luck...:thumbsup:
   / Restoring old barn Timbers #10
I am glad you want to preserve the hand work of your great grandparents. You cannot replace such treasures.
2013 Magnum Power MLG08 Towable Runway Closure Marker Light Tower (A55851)
2013 Magnum Power...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 Case IH 1250 24-Row Early Riser Planter (A53485)
2012 Case IH 1250...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A55745)
2011 FREIGHTLINER...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
2020 Case 5550 Trident (A55314)
2020 Case 5550...
