Restricted flow in copper pipes, iron buildup
   / Restricted flow in copper pipes, iron buildup
dmp437:
Good suggestion. I have a similar setup between the softener and the pressure tank, I can throw a few fittings in there and try the same thing.
thanks
dmp437:
thanks
   / Restricted flow in copper pipes, iron buildup #23
Did it help that I diluted the 1 1/2 gallons of bleach into 5 gallons of water? And poured the mixture into my well 'slowly" with water running into the well at the same time?
Also, I let it sit in the well and pipes for 10 days. Was that long enough?
Bob
   / Restricted flow in copper pipes, iron buildup #24
Bob
   / Restricted flow in copper pipes, iron buildup #25
I'm sure it helped, but I wouldn't recommend doing it too often for those reasons.
By the way, most water softeners do not handle ferric or ferrous oxide well, so those of you with a lot of iron in your water, you might try using a special salt which helps.
The iron tends to bind very strongly to the Ion Exchange resin, and it doesn't backflush very easily. After a while, the unit will lose the capacity to soften. If you can't afford the chlorination system ahead of the softener, then at the very least use the sodium designed to help remove the iron.
hope this helps.
anthony
   / Restricted flow in copper pipes, iron buildup #26
hope this helps.
anthony
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
