restrictors for hydraulic hoses
   / restrictors for hydraulic hoses #11
Heck,I didnt know you wanted to do this as cheap as possible. You could just take a small pair of vise grips( you probably have sone lying around)and clamp them on a hose. At least this way cylinder speed is still adjustable. Norton
   / restrictors for hydraulic hoses #12
norton said:
An adjustable flow control like mchasal described is the way to go. However,if you want your cylinders to exdend and retract at the same speed,you will need 2. One for each port on the valve. Because cylinders extend slower than they retract given the same flow rate. This is also why they meter oil only in one direction. Norton
Norton, I know you mean well, but your advice is "junk science." If you put a restrictor into one line, all the fluid that flows thru it has to flow thru the other line too. It doesn't matter whether you are extending or retracting the cylinder. All flow has to go thru a single restrictor. If you add a second restrictor (one in both lines) then all the fluid ALWAYS flows thru both of them; no difference.
Of course, if you are driving around with a half-dozen "adjustable" vise grip restrictors hanging off all your hydraulic lines, then this won't make any difference to you.:rolleyes:
   / restrictors for hydraulic hoses #13
Gee Jinman,I would think before you post a reply,you would at least look at the adjustable flow control Mchasal described and see how it operates. If you notice it has an internal check valve that allows full flow in one direction, and meters oil in the other. Therefore it only is a "restrictor" in one direction. By using 2 of these you can adjust cylinder speed independly in both directions. Its not junk science,its hydraulics. Norton
   / restrictors for hydraulic hoses #14
norton said "Its not junk science, its hydraulics. Norton"
He he he -- good one!
jb
   / restrictors for hydraulic hoses #15
Norton, your responses are neither good hydraulics nor economics. You are suggesting spending about $75 for two adjustable valves and then with the adapters you have to add to get them into the lines, you're up to at least $100.
Now, where are you going to put them? Are you going to mount them inline on the hoses at the quick connects? Do you have room? Are you going to build a mounting bracket for them in the operator's platform and then have to plumb in the lines? Talk about expensive.... I can easily see your "hydraulics" costing more than the cylinders you are trying to control. Let's say you have both TnT and a grapple like I have. Now you are up to six of these little "jewels" in your system.
But wait.... We could use the non-adjustable type, right? Well, not really. Did YOU read the specs? The minimum flow for the non-adjustable type is 4.5 gpm. Heck, that's half my maximum flow rate. I gain NOTHING by putting one, two, or more inline. They're $8 each plus shipping for no gain whatsoever.
So yes, Norton, you could put these into your system and you'd have one big overbuilt waste of money system with possibly a plumbing spiderweb to boot. These valves were never meant to be used for tractors. They are for critical control of systems far more complex than a grapple or TnT. To use them on a tractor is a kludge.
You suggested I had not read the specs for the valve from Surplus Center. In fact, I've read the specs of these valves many times before and also the valves available from Bailey (www.baileynet.com). I also have many of the $4.95 orifices in my tractor's hydraulics system and they work beautifully. So I'm not just aware of what is available, I'm also a seasoned veteran of many hours of use.
When I used the word "restrictor" in my reply to you, I did not say "adjustable valve" because I was not talking about an adjustable valve. A single $4.95 ristrictor can do exactly what you need and my comments about the flow having to go thru the orifice in both directions is true. There is no checkvalve in a restrictor.
The reason I first responded to you was your flippant statement that you could use a set of vise grip pliers to control flow if you wanted cheap. When was the last time you bought a pair of vise grips? Were they less than $4.95? Please take the "vise grips" off your opinion and listen to the many folks here who have lots of experience. Please don't belittle what is good and well thought-out advice.:)
   / restrictors for hydraulic hoses #16
You could put a servo valve in there and then program an embedded micro-controller to run it. A digital keypad and display could allow the operator to enter the desired rate in either direction in inchs per minute. It could automatically correct for the difference in cyclinder displacement in both directions too. Heck, add a thermistor and we can correct for the temperature so the motion rate is the same at any temperature. Add a linear transducer and we could position it too.
But, I used the resistrictors on my tractors. Sorry, I couldn't resist, this is too much fun.
   / restrictors for hydraulic hoses #17
I see,beacause you dont understand it,it must be wrong. Norton
   / restrictors for hydraulic hoses #18
My dealer put restrictors in my TNT lines. He used hoses that ended w/a fitting that had a short bent metal tube between the hose & the fitting nut. He said this type of fitting was needed near the restrictor because they concentrated the hydraylic flow into a small streem that'd cut thru a rubber hose. Don't know if this is ssscience or fiction but my hoses don't have any holes!
2015 Ford F-250 Knapheide Service Truck (A55788)
2015 Ford F-250...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
NEW 24ft Feed Bunk Wagon (A55301)
NEW 24ft Feed Bunk...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2025 epic golf cart (A55758)
2025 epic golf...
