RET or anyone who has cut down pto for the BX2200
   / RET or anyone who has cut down pto for the BX2200 #1
GAKubotaFan
Stockbridge, GA
Kubota B7800
RET I noticed that you have a BX2200 and also had to cut down your PTO for you tiller. I also have a BX2200 and a 44” First Choice tiller. I was wanting to know how much or short the PTO needs to be. How do you know what length to cut the PTO. What do you use to determine what is too long or short? Anyone who has any answers I would appreciate them.
   / RET or anyone who has cut down pto for the BX2200 #2
When I cut down the shaft for my spreader, I just "eyeballed" it and figured slightly long. You need to do that with the tool mounted on the 3-pt. Be sure to check it both raised and "down".
   / RET or anyone who has cut down pto for the BX2200 #4
Hello, I just cut my PTO shaft for my BX2200 and a First Choice 48". I measured just like described in the other post, I cut it a little long, and cut it three times to keep it the max length (overlap) and not end up too short. I used a sawzall, and it took less than ten minutes for all of it.
Good Luck!
--Jim
   / RET or anyone who has cut down pto for the BX2200 #5
GAKubotaFan,
I did as described above. Took rough measurement after hooking up tiller to tractor. Made equal cuts on each of the 2 shaft sections with a sawzall, pieced it together, took it back apart and cut a little more, etc. Took 3 tries if I remember right. Wanna make sure you have plenty of overlap when two sections are put together, but you wanna make ABSOLUTELY sure neither piece will 'bottom out' in the raised position....'cause something expensive may give way if that happens. I can take some measurements of what I ended up with when I get home this evening if that would help. Let me know.
RET
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
2022 JOHN DEERE 6120M LOT IDENTIFIER 170 (A53084)
2022 JOHN DEERE...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
2020 JOHN DEERE CP690 LOT IDENTIFIER 246 (A53084)
2020 JOHN DEERE...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
