Rethreading hole for grease fitting?
   / Rethreading hole for grease fitting? #11
mark.r said:
Thanks Jerry. So that I am clear, this four way tool is a specialty item made just for grease fittings or is a more universal tool for rethreading all types of threads? You wouldn't happen to know what it's called would you?
Thanks for the heads up.:)
It is made specifically for grease fittings. I don't know where you would find a metric one but I am sure they make them. I can't see them being made for SAE and not metric. Here is what the tool looks like. Click on the little plus (+) beside the number.
Easy-Out Fitting Tools - Alemite
   / Rethreading hole for grease fitting? #12
TSC sells both metric and sae tools.
I have each. It has a broken zerk fluted extractor.. a thread chase, and a couple nipple wrench ends.
I'd used this tool to thread soft aluminum housings to install zerks after predrilling a pilot hole, and for chasing bad initial threads in stell.. works fine ans JerryG said.
Soundguy
   / Rethreading hole for grease fitting? #13
Forgot to add.. smear grease ont he chase section.. screw in, and then back out to clear the chips. If you are lucky.. the grease on the chase will entrail the metal chips..
Otherwise i like to have the joint disassembled to clear the metal out.. i know in some cases it is not possible.
Soundguy
Soundguy
Ok, I will check with them at lunch today. They must stock them in the tool section and not near the replacement grease fittings. I am assuming that since I am just cleaning up a hole there is not need to do any pilot drilling although using a bit of grease to help "grab" the metal shavings is a good idea.
   / Rethreading hole for grease fitting? #15
At my TSC they are near the grease fittings.. etc / grease guns.. etc.
You already have a hole.. you just need to chase it.
If that don't work.. try the next largest size 'drive' fitting to make it fit.
Soundguy
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A59228)
1994 Generac...
AEREATOR (A58214)
AEREATOR (A58214)
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2024 Spartan SRT-XD Zero Turn Mower (A59814)
2024 Spartan...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
