retired 76
/ retired 76 #1
ebo4869
bybee, tn
2006 mahindra 6000 4wd
mahindra 6000 4wd, clutch not releasing to engage gears, have tried adjustment, ant tips other than dealer?
/ retired 76 #2
Welcome to TBN.
Was it parked for a long time? If so the clutch disc may have stuck to the pressure plate. I had that happen with a Ford 3000 series tractor and once with a car. Both had been sitting for several months. I freed it up by driving them around. If you can start it up in gear and drive it around going both up and down grades varying the throttle, the weight of the tractor should free it up. The ones I had freed up in about 10-15 minutes of driving them. I'm not sure but suspect that's your problem.
/ retired 76 #3
Ditto on what George2615 said. I had an old Chevy one ton that if I let it sit, the clutch would stick to the pressure plate. You had to free it up like George2615 said. I pushed the clutch pedal in, then used a piece of 2x4 to hold it to keep the clutch plate from sticking when not using the truck.
Sky Jack SJ8831RT 4x4 Rough Terrain Scissor Lift (A61572)
Sky Jack SJ8831RT...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
