reversal of hitch pins?
   / reversal of hitch pins? #1
fyrcapt
Fl.
Mitsubishi 2300II
I have a mitsubishi D2300. I recently purchased a King cutter rotary cutter. When I tried to hook it up to my hitch I noticed that the lift arms seem to be spread to wide and will hit the tires. I guess I can reverse the rims but I also noticed that if I reverse the hitch pins to the inside of the cutter I will have the correct spacing. Does anyone see a problem with this? /forums/images/graemlins/confused.gif
   / reversal of hitch pins? #2
</font><font color="blue" class="small">( if I reverse the hitch pins to the inside of the cutter I will have the correct spacing )</font>
That's a quite common solution; no problem with it at all.
Thanks for your speedy reply. I really appreciate it.
   / reversal of hitch pins? #4
I had the same problem with my old B7500 and a KK 4' brush hog. I think not only did I reverse them, I lowered them too, so my brush hog would raise higher. When I bought new implements I would tell the dealers to reverse them for me. Sure makes hookups easier.
   / reversal of hitch pins? #5
I reversed the hitch pins on much of my KK and other equipment when I just had my ym1700. Also remember to use chains to keep stuff outta your tires. Dishing out the rims helps with width and stability issues.. just remember to swap the wheels from side to side to keep the tread 'pulling' the correct direction.
Soundguy
   / reversal of hitch pins? #6
My KK back blade came off TSC's lot with the pins reversed. Works fine for my BX2200.
   / reversal of hitch pins? #7
I reversed the pins on my KK finish mower that is on my Yanmar. The only problem that I see is that you are spreading the PTO shaft, so be sure that it is long enough. A PTO shaft loose would not be fun. oldhippy in Ark.
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
20711 (A50323)
20711 (A50323)
