Reviews on a TC34DA
   / Reviews on a TC34DA #1
rjoseph
Akron, Ohio
NH TC34DA w/SS
Hi,
I orderd a NH TC34DA w/SS, 72" Mower, and a 15LA FEL. I was looking for your input and advice. The TC34DA is new as of April, 06. Thank You!
PHP:
   / Reviews on a TC34DA #2
I love it 150 hrs plenty of HP
you will not be disappointed.
I didn't know you can put the 15LA on it mine came with the 14LA hmm.
I dug a 1200 foot tench around my property (cutain drain) no problems rip up roots stumps you name it.
added more fill 100 yds for grading issues, 80 tons of rock for the drain, lifts no problem,
the QA fork lifts large trees with ease--I have to learn how to upload pictures.
Drives like a Caddy.
Should I go on.
   / Reviews on a TC34DA #3
I am just curious. What will the TC34DA withe 14LA FELdo that the TC33DA with 14LA FEL will not or cannot do? I suspect that they are nearly identical with the exception of 1 or 2 horsepower.
   / Reviews on a TC34DA #4
The TC34 is really all about torque. The engine is much higher displacment with a better torque curve. Its only 1 more HP, but it can do much more work.
   / Reviews on a TC34DA #5
I've had mine since springtime and can't say enough good things about it. Only work to date has been mowing (6' RFM) and bush hogging (5'), but I'm real pleased with the power it puts to the implement. The HST is cool, and the R4 tires have been easier on the lawn than I would have thought. I can't imagine that you will regret your choice.
Should I go on.
First, Thank you for you input. It's a good feeling when you spend 26G's and it's going to do the JOB!...
FYI; The TC34DA is 35 HP, and the 15LA FEL works with SS...Bob
   / Reviews on a TC34DA #7
I have allmost 50 hours on mine and no problems. I moved from the TC24 to the #4 and I have not looked back. Good power litter more on fuel but who cares. I just picked up a 6 sweepster and it handle it good. I do notice while working my RPM's are alot lower on this tractor.
   / Reviews on a TC34DA #8
I have about 10 hours on my TC34 and am really glad I got this model. It has the same engine as the TC35, but in a more compact frame - so you have really good HP to weight. I don't think there is another tractor of comparable frame size that is better....
of course I am biased now...
Genie GTH-5519 (A50123)
Genie GTH-5519...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED FUTURE FT-SCW46 STEERABLE COMPACTING WHEEL (A51248)
UNUSED FUTURE...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2022 RHINO X1808 LOT IDENTIFIER 66 (A53084)
2022 RHINO X1808...
