Backhoe Rhino backhoe?
   / Rhino backhoe? #1
tman1020
north west indiana
Bobcat ct225 and Bad Boy zero turn
Anyone out there have a rhino 75C backhoe. I have the bobcat version of the CK 27 and would like to put a backhoe on the back of it. I'm wanting to know if you have to remove the three-point linkage in order to install the subframe mount backhoe. Also if anyone has any experience with the rhinos good experiences or bad would appreciate hearing about them. Thanks.
   / Rhino backhoe?
Also was wondering if anyone has tried the 8TB other tractor.
   / Rhino backhoe? #3
I don't have a 75. But I run a Rhino 85 on my DK 35 and the 3 point linkage can be left on.
   / Rhino backhoe?
Thank you DKvince. I'm thinking about trying to put that TBH8 on my CT 225. I know it's one size larger than they recommend. What's your opinion on it does your tractor Handle the eight no problem do you think it would be okay on a slightly smaller frame?
   / Rhino backhoe? #5
My Rhino 85 is an 8 1/2' backhoe. My DK 35 handles it with no problem.
I'm not familiar enough with the CT or CK series to say how an 8 would work.
   / Rhino backhoe?
Thanks again for the info.
   / Rhino backhoe? #7
I have a 8tb on my ct335 bobcat tractor, my 3 point hitch was removed to accept the subframe and backhoe, not sure it can be left on but I don't think it would leave much room. Overall I am very pleased with the hoe, she's very well built, the subframe ties into the tractor very well. The controls are very comfortable and responsive for a small hoe. I would recommend trying to find a 8tb if possible. I have owned a woods 7.5 and it was also a nice hoe however it does not compare to the bobcat 8tb.
   / Rhino backhoe?
Thanks again i'm still hunting having a hard time finding the bobcat version may have to go with the rhino version. I just hope that I can leave the three-point linkage on. I also would like for the subframe to stay on the tractor when I remove the backhoe wonder how hard that will be.
   / Rhino backhoe? #9
The sub-frame is bolted to the backhoe and clipped with pins to the tractor. Much easier to take it on & off with the sub-frame. I think, not sure, the sub-frame sticks out the rear some and might interfere with using 3 point attachments. If the sub-frame is problem for storing the backhoe, remove all 1 bolt on each side and swing the frame vertical and strap to the hoe.
   / Rhino backhoe? #10
I think if you want the subframe to remain on the tractor you need to go with Woods with the 4 point type frame. But I believe the 3 point must be removed for this style backhoe to be installed.
The Bobcat/Rhino subframes are attached to the backhoe and come off with the hoe.
   / Rhino backhoe? #11
The bobcat version subframe stays with the hoe, it's a matter of minutes to remove the hoe, the sub frame also greatly reduces your ground clearance, you would want it off when don't using the hoe.
   / Rhino backhoe? #13
I have a Rhino 75. You can leave the 3pt on the tractor. The subframe does come off with the tractor. Two pins holds the hoe onto the tractor. The hoe works great. Smooth and powerful. The hoe comes off in a minute or two. Putting it on can be a pain, as you have about an inch of left/right play to get the rear bar aligned with the hooks. Sometimes I can get it on in about 5 minutes. Other times it take 15. If you store it on concrete or pavement, I'd think it would be easiest. I don't have that luxury. I have a few hundred hour of use and it has always worked very good. Suggest you get two buckets: 18" for general digging, and a 12" for trenching. An 18" trench is monster for a 2" pipe.
   / Rhino backhoe? #14
Depending on your application a ripper tooth might be a good option as well, I sure with I had one the other night while removing some ironwood stumps.
   / Rhino backhoe?
I'm thinking a 16 for starters. But I may have to take what I can get if I find a bobcat brand one. I think I'm getting closer. Do they make after market thumbs and rippers for the bobcat/rhinos
   / Rhino backhoe? #16
The dealer should be able to offer you several options: buckets, thumbs, rippers, what not.
   / Rhino backhoe? #17
I would look at Woods. Subframe stays on tractor and helps support front end loader. 3 point can stay on with backhoe, no loss of ground clearance. It also helps to protect Hydro filter. You get what you pay for. IMO.
   / Rhino backhoe? #18
I may be speaking out of turn but I thought the Bobcat tractor was a rebranded Kioti, in which case wouldn't a Kioti BH fit? What is the Kioti equivalent to a CT225?
   / Rhino backhoe? #19
You are correct, the bobcat is a rebranded kioti I would assume a ct 225 is equivalent to a ck 25? Please correct me if I am wrong.
   / Rhino backhoe?
Yes mostly. The same company that makes kioti also makes the bobcat tractors. They r almost identical except for color and other minor differences. Loaders r different though I be leave a kioti backhoe will fit no problem and I believe is a good backhoe. But. The price is as much as a woods and it is orange. So far the rhino/ bobcat hoe is the best price for quality backhoe and made in USA and if I can find a bobcat one it would be oem and match my tractor.
1998 MACK RD690S DUMP TRUCK (A60430)
1998 MACK RD690S...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
