RickB, et al:IS the TD95D an all metric machine?
   / RickB, et al:IS the TD95D an all metric machine? #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
I've been doing some checks on my 2007 TD95D and so far every fastener I've touched is metric. As it's made in Italy I think the odds are real strong that all the fasteners are metric. Can you confirm this? I want to put a tool kit together to carry in the tractor so I don't have to run back to the shop if i need to tighten something, bleed a filter, etc.
Thanks in advance for any help.
   / RickB, et al:IS the TD95D an all metric machine? #2
RickB will provide the definitive response, but I have a TN55 manufactured in Italy and it is all metric. Well, at least I haven't discovered any non-metric fittings since 2000.
I was looking through the on-line parts catalog/diagrams at Messick's and discovered that there was a tool kit (all metric) available for the TN55.
If RickB or another expert doesn't chime in, you might try searching Messick's NH parts catalog/diagrams to see if such a tool kit is available for your model.
Steve
   / RickB, et al:IS the TD95D an all metric machine? #3
Neighbours is all metric so far, but made in Turkey not Italy. Old Fiat design if I recall correctly.
The data plate on mine says "Made in Italy".
   / RickB, et al:IS the TD95D an all metric machine? #5
It's Italian, and all metric.
   / RickB, et al:IS the TD95D an all metric machine? #7
I don't think we are talking about the same model, I must be mistaken. Theirs is the model with the spur gear reduction units on the rear end made in the old Fiat factory.
EDIT I believe the ROPS data plate on the cab says made in Italy.
Thanks guys.
Ford 345C Tractor with Loader (A51573)
Ford 345C Tractor...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
