RickB or Jbrink64-TD95D engine oil refill quantity
   / RickB or Jbrink64-TD95D engine oil refill quantity #11
Some of the compacts have 2.
   / RickB or Jbrink64-TD95D engine oil refill quantity #12
Some of the newer NEF "structural" engines have oilpans that come down arounf the front driveshaft like the larger compacts mentioned. These pans all have drains on either side of the driveshaft relief.
   / RickB or Jbrink64-TD95D engine oil refill quantity #13
Oops, I forgot about those. Sorry, my bad.
Here's the latest from my local New Holland Dealer regarding the oil refill capacity for a TD95D. They admitted the manual specified capacities were in error. They said that this model used several different engines. She asked "So what'sthe correct refill quantity?" and they said the engine was the same as the JX95 (CaseIH) and it used the same dipstick (P/N 99441833). The Case IH numbers say 8.4 quarts to refill the crankcase + 0.74 qts to fill the filter for a total of 9.14 quarts. They apparently never specifically did give her a direct answer to what the TD95D was but it's safe to say that if the correct dipstick is used you will put the correct quantity in the crankcase. The service manager in Dillon (the main office for the local NH dealership) said, since I put three gallons in, drain off a gallon and refill to the dipstick. That will give me an idea of the correct quantity. That's what i was planning on doing. New Holland did say that they are going to revise the manuals.
So until I drain out some oil, I'll go with the 9.14 quarts and use the dipstick to to check.
Thanks to RickB and Jbrink64 and Sweep, who took the time to answer. You guys can mark your manuals with this info until the heavy breathers in Racine send you the manual revisions.(I think CNH is headquartered in Racine aren't they?).
   / RickB or Jbrink64-TD95D engine oil refill quantity #15
Glad that's taken care of.
Just to close this issue out, I removed about 2.9 quarts of oil from the 12 quarts I put into the crankcase today and that lowered the oil level to the "Max" mark on the P/N 99441833 dipstick in my tractor. This confirms the numbers i got from CNH yesterday.
I would call the engine oil refill capacity of the TD95D with the Iveco 8045.25L engine 9 quarts with an oil filter change.
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
Generac Generator (A51691)
Generac Generator...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
