Rim Guard Cost
   / Rim Guard Cost #1
Sockwell
Coosa County AL
Kubota L5740-HSTC,CC/Y EX3200, 1950 8N
Just ball park, what can I expect to pay for Rim Guard? I'm going to need about 75 gallons.
   / Rim Guard Cost #2
I checked this out a few months ago.
About $0.30 per lb, about 11 lb/gal, so about $3.30/gal.
What I don't know is whether this is the cost of the material only or if it includes a fee for filling your tires.
Call the lady at RimGuard. She's very helpful.
   / Rim Guard Cost #3
Shop around, I found about $100 difference between Rimguard dealers for filling the tires in my 50 hp tractor.
Ken
   / Rim Guard Cost #5
ever think of getting wheel weights as opposed to rim guard? the cost wont be that much more and it will be lots easier to repair should you ever get a flat/leak. also changing the tire pressure to you liking would be an option with wheel weights
   / Rim Guard Cost #6
ever think of getting wheel weights as opposed to rim guard? the cost wont be that much more and it will be lots easier to repair should you ever get a flat/leak.......
Price of Rimguard is going to vary, but I paid $3.00/gal a little over a year ago. It pays to shop around when buying Rimguard.
You do not need inner tubes with Rimguard like you do with calcium chloride, so a tire may possibly be repaired (plugged) without removing the wheel from the tractor -- same as if you have mounted wheel weights and tires w/o inner tubes.
   / Rim Guard Cost #7
Wheel weights generally don't add as much weight as Rimguard (I have 800# per tire on my M9540) and usually cost a lot more for the same weight. I'm not sure serious wheel weights are easy to remove/replace.
I don't see where Rimguard stops you from varying the tire pressure. If used without tubes, leaks can be plugged without removing the tire.
Ken
   / Rim Guard Cost #8
Filled tires also add a greater amount of stability than a wheel weight can.
   / Rim Guard Cost
Thanks for the help guys, but I'm gonna have to look for Plan B. I just got off the phone with Rim Guard and their nearest dealer is in North Carolina, about 5 or 6 hours away. The guy was very friendly. He said folks this far south aren't worried about freezing. I was looking at it more from an environmental point. Guess I'll look for an environmentally friendly anti-freeze.
   / Rim Guard Cost #10
You'll want to look into RV anti-freeze--propylene glycol--that's used in potable water systems on RVs. You can drink PG. The usual antifreeze is ethylene glycol--poisonous.
The density of water-antifreeze mix is not much different from that of straight water (8.33 lb/gal).
Gehl 135 Mixer (A49251)
Gehl 135 Mixer...
12-16.5 Forerunner SKS4 Tires (A49251)
12-16.5 Forerunner...
Vehicle Roof Rack (A46687)
Vehicle Roof Rack...
Pallet Fork Frame (A47371)
Pallet Fork Frame...
2015 John Deere 5065E 4WD Utility Tractor (A49346)
2015 John Deere...
4-Compartment Metal Storage Box (A49346)
4-Compartment...
