Rims for a 1986 ford 2110
   / Rims for a 1986 ford 2110 #1
mtestagolf
leominster,ma
new holland tc33d
My ford 2110 has calcium loaded tires in the rear. The rear left rim if rusting out and I called the dealer the other day and he gave me a price of 1100.00 for the outer rim, it is a 2 piece rim with 8 loops. Anyone have any suggestions or are there aftermarket companies that sell them. Thanks Mark
   / Rims for a 1986 ford 2110 #2
Unverferth sells rims, but this would be custom OR you can buy a blank rim without the hoops, order the hoops separate and weld them in place.
Also, I may have a rim.
   / Rims for a 1986 ford 2110 #3
Take a look around this site Loop Rims
Blank Rims
Hey Wheel
If they don't have what you need I'm sure they could make it up for a lot less than $1100 and probably less than Unverferth also.
Good luck.
   / Rims for a 1986 ford 2110 #4
Bet it's rotted around the valve. Good tire guy can cut that out and weld in a new section from a similar rim (speaking from experience).
   / Rims for a 1986 ford 2110 #5
Good luck on your issue. I also need to replace/ repair my rear rims for a ford 2110 1987 I believe. Keep me in the loop if you find a deal on rims etc. thanks
   / Rims for a 1986 ford 2110 #7
will look into that. Now will a tire place re install the tire because of the modification and not DOT approved. I heard that I go this rout that some places wont do it because of the welding of new patch.
   / Rims for a 1986 ford 2110 #9
DOT has no authority regarding tractor tires or tractor wheel equipment.
   / Rims for a 1986 ford 2110 #10
I doubt Unverferth sells direct retail. our dealership has direct bolt on rims for this application custom built, as well as a couple other NLA or overly expensive Ford/ NH rims.
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2013 Nissan Pathfinder SUV (A50324)
2013 Nissan...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
