Ringo Farms 6x10 Dump Trailer, Not Dumping ?
   / Ringo Farms 6x10 Dump Trailer, Not Dumping ? #1
Kevin M
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
I have a Ringo Farms 6x10 Dump Trailer and its not dumping. It was working fine. I bought this used in good shape with not alot of use. It has a brand new battery, Electric motor is spinning but nothing happens ? Its a power up, gravity down setup and its full of what appears to be ATF fluid. Its an electric pump with integrated reservoir, Any thoughts ?
   / Ringo Farms 6x10 Dump Trailer, Not Dumping ? #2
Any way to bleed the pump - if they get air in them, they don't syphon/ suck oil very well. Or a leak in the suction hose, it is sucking air instead of oil.
Got a brand name on the pump unit, might help someone help you.
--->Paul
I will try bleeding it later today and also post the brand name. Thanks
After 5 minutes with a test light , turned out it was a poorly engineered crimp connector on the solenoid valve. I cut it out soldered the wires and shrink tubed them. Fixed !
For the extra time it takes to solder , it avoids problems like this ! Did I mention I HATE solderless connectors.
7ft Titan Box Blade (A57453)
7ft Titan Box...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
2013 PETERBILT 386 MID-ROOF SLEEPER (INOPERABLE) (A58214)
2013 PETERBILT 386...
CASE IH 496 DISC HARROW (A52708)
CASE IH 496 DISC...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
