rip cutting into a stump
   / rip cutting into a stump
   / rip cutting into a stump #12
I would think the gas/whatever would keep the fungi from attacking the stump, and slow the rotting? No?
How does the salt/powdered milk work? And how well?
Thanks, Jim
   / rip cutting into a stump #13
You could drill holes in it and pour stump rot into it also.
The milk supposedly makes the fungi get to work faster. According to the article anyway.
I looked up the stump rot chemical, and It would be expensive for me. There are about 100 plus stumps of various sizes.
   / rip cutting into a stump #15
Would a backhoe be easier or maybe TNT (smile)?
   / rip cutting into a stump #16
It may be a little off the subject but.
From what I have read and heard. The reason stumps take so long to Rot out/Decay enough to be popped out of the Ground. Is that the growing tree is cut down, it tries resprotting and continues "Trying" to grow for 2 or more years after the tree has been cut down.
So What I am trying is Kill the Tree first, in the spring, if it is not standing close to something that can be damaged if the trees should fall during a storm let them stand all summer possibly 2 seasons. Then fall the tree leaving a 4 foot stump, for leverage and try pulling/popping the tap root to remove the Stump.
I found a BroadLeaf herbicide at a Farm supply store , "Lamine 2-4 D" relatively cheap $34.99 for 2.5 gallon, and it has instructions for "Forestry Use". It refers to using a "Tree Injector" and injecting so many ounces below the bark, based on the Size of the Tree Trunk. I put a small Generator on a trailer and drove around to a few "Test" trees and drilled 1/2" holes 3" deep at 12 ,3, 6, 9 o'clock positions downward at an angle, bought a Turkey baster to fill the holes, and I filled the holes with the 2-4 D
I did that May 27th, The trees were in full foliage , after less than 2 months , not any more:D , not a leaf on any of the Trees. Now I will wait til the winter, fall one of the test trees and try pulling or digging under stump with FEL in moist spring dirt to see if one season is sufficent or if they need to stand longer for the root system to decay for easy stump removal.
All that being said, if your are on a tight time frame and the trees and stumps must be removed fast, this process is out.
   / rip cutting into a stump #17
Just remove a layer of bark from around the tree. It will die. This used to be done in the long ago when clearing land using horses and hand labour.:D
Yep. Girdling the tree. I actually remember learning that in like 4 th grade.I wont hint what year though.LOL
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
