Roadside Plastic Barrier Errosion Control?????
   / Roadside Plastic Barrier Errosion Control????? #11
It is part of the building code in most municipalities. I think it might be in the model codes they all adopt.
In my city, bujilding our house, the first inspection of the foundation excavation also included inspection of all the silt fences. No silt fences, no passing the foundation inspection and no proceeding with the project.
The building permit included a deposit that would be forfeit if among other conditions, proper runoff control (silt fences, etc) were not kept in place during the project.
Also, the state has some pretty stiff fines for uncontrolled runoff from a construction site into a lake, river, or stream.
They do work. Down by the lake after a big storm, the silt fence was over-flowing. It was about 18" to 24" high. The stakes barely held the water.
Later when the water drained down, I discovered that there was about 18" of silt that had collected behind the whole area of the fence. It took half a day of digging with my little 4100 to "empty" the silt fence just in time for it to start raining again.
The contractors who knew about silt fences because they have to deal with putting them up and maintaining them themselves were careful not to destroy the fences. Those who didn't know or care, seemed to delight in running over it with trucks, cranes, and Bobcats.
Installation is manual-labor intensive. The fence is required to be anchored into the ground in a slit or have the bottom covered with enough dirt so as not to let water under-flow it or otherwise leak. The stakes have to be big enough to hold the weight of the water flow back.
For long fencing runs, there is a 3-point attachment that will slit the ground and install the material from a big roll. The fancier attachments can even pound in the stakes for you they goes. Could be a nice business opportunity for somebody with a CUT and one of those attachments going around on bigger construction sites.
- Rick
   / Roadside Plastic Barrier Errosion Control????? #12
The silt fence is another example of a great idea that sometimes, bureaucracy can turn into a farce. Ever see one that surrounds a project in a valley or a swale - what's the silt fence supposed to do in a case like that?
   / Roadside Plastic Barrier Errosion Control????? #13
The city actually did a good job of indicating where to put the fences on my project. But yes, there are lots of projects with miles of silt fence that never touch a drop of runoff.
Lots of other projects where they throw three bales of hay into the ditch and call it watershed management.
- Rick
   / Roadside Plastic Barrier Errosion Control????? #14
Whoops <font color="red"> slit fence, silt fence </font> past 9 PM I guess that I get a bit dyslexic I guess, sorry... /forums/images/graemlins/frown.gif
   / Roadside Plastic Barrier Errosion Control????? #15
Mike,
Dont' be sorry, your in good company <font color="red"> heer </font>... /forums/images/graemlins/tongue.gif
Don
   / Roadside Plastic Barrier Errosion Control????? #16
After digging out my pond, I wanted to make cut down on the amount of dirt that would run-off when it rains, so I installed a double barrier silt fence. It's about 20 feet apart, so I can get in and clean up after the really big storms. I can get 2 to 3 inches in a couple of days, so the run-off can get pretty bad. Once I plant grass, this won't be a problem, but soil temps have to be in the 70's for the bermuda to grow. That means mid April.
   / Roadside Plastic Barrier Errosion Control????? #17
It does a good job of holding water, too!
During last year's monsoons, we got quite a few calls from concerned neighbors.
Seems that the silt fences backed up water on the upstream side... on one fence, the water was 2 ft. deep! People worried that the silt fences would break and spill silt and water across roads, creating traffic hazards.
   / Roadside Plastic Barrier Errosion Control????? #18
I took a walk across the street from my commercial property a few minutes ago. This first picture shows a 20,000 sq ft property. The silt fencing goes all the way around, but not at the temporary driveway. There was a light rain when I took these pictures.
   / Roadside Plastic Barrier Errosion Control????? #19
The property next door, about 40,000 sq. ft., is also under development (these will be warehouses). They've done a pretty good job for the most part, but work really hasn't started.
   / Roadside Plastic Barrier Errosion Control????? #20
A good job, that is, except at the corner and the swale.
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
Skid steer auger plate (A50322)
Skid steer auger...
