Robin 422 engine main bearing seal gasket replacement
   / Robin 422 engine main bearing seal gasket replacement
Is that the Pulse Fuel Line?
If so you should replace, not repair if you can...
Yes it is. I have to remove the muffler and the battery to do that and the battery is nearing end of life. It's about 5 years old. When it goes I will replace the line. I think this was actually my biggest leak. It seems to be good for now. Knowing me, this Fall I will probably put in a new battery.
Just to summarize this. All of the oil leaks have stopped. The governor shaft seal stopped leaking. I guess this was caused by fixing the pulse fuel pump line. It's nice to have the engine clean, well mostly. There is still some trash in the tub.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2025 Homemade 18' Trailer (A57149)
2025 Homemade 18'...
WARREN LIGHT TOWER (A58216)
WARREN LIGHT TOWER...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
UNUSED FUTURE MSG24 24" HYD MINI STUMP GRAB BUCKET (A58376)
UNUSED FUTURE...
