Rochester MN S/N 26544
   / Rochester MN S/N 26544 #1
Peglomaniac
JD 4020
I am not sure how to find details on this tractor, wherever I search, the serial number doesn't match what I'm finding. The S/N tag I found is inside the cab. I'm trying to date it for starters, & get any more info I can.
Welcome to TBN <snip>
Your location would help us too. thanks
Southern Saskatchewan, Canada.
I also learned that when my husband got it, the transmission was FUBAR so he put two tractors together to make it work so I am not sure if the photos are all true to the original front end / interior.
   / Rochester MN S/N 26544 #4
The tags that I see are for the cab, a couple for the RoosaMaster injection pump, but I'm not seeing the one that is on the rear by the PTO as indicated location on the Tractor Data .com site.
Let us know if there is a tag on that rear by the PTO. Might be a victim of the change to the transmission which is ahead of the rear end differential and axle. Circled in white is where the s/n tag may be hidden by oil and dust.
   / Rochester MN S/N 26544 #5
A Deere 4020 is a very ubiquitous tractor.
200 thousand built. Good stuff!
   / Rochester MN S/N 26544 #6
Your tractor was manufactured '64-'68. As beenthere stated serial # of rear of trans case will narrow down the yr model.
2012 PETERBILT 365 (A55745)
2012 PETERBILT 365...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A55745)
2013 3400QB...
Zero Turn Mower (A55853)
Zero Turn Mower...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 72in Dual...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
