rock removal ideas?
/ rock removal ideas? #41
I was going to try herding the rocks with the rake like that, but didn't think it would work. Going to start working the foodplots next week. I'm sure numerous rocks have sprouted since the fall. I'll give it a try with the rake. Might be easier than skimming them with the box blade.
/ rock removal ideas? #42
There is a great post about a several acre commercial site in Halifax, Nova Scotia that the owner wanted rock free to a depth of 2 feet or something like that. The contractor ended up lowering the entire site by 4 feet or something and only had 6" of rock free soil.
/ rock removal ideas? #43
We built a horse riding ring last year and had a 10" layer of compacted screenings (Crushed stone dust) put over the compacted subsoil. This was followed by the sand layer for riding. The compacted stone is used specifically to prevent upward migration of rocks from the subsoil layer in to the riding surface. It is extremely effective but very costly. I think without something between the dirt and sand you will always have rocks migrating to the surface especially after a freeze thaw cycle. It takes alot of screenings to do this and some ring contractors use only a 6" layer. Our ring (80' x180') took 28 triaxle dump truck loads of stone to achieve a 10" layer. Just my two cents, but that is how rings are constructed in southeastern PA.
/ rock removal ideas? #44
Another way ...
Golf course construction (200-400 acres) requires rock-free soil to a substantial depth to protect mowers and aeration equipment.
I believe that they rent an industrial screener which they park in one place, scrape and truck the topsoil to it, feed it with a rented conveyer, then truck it back and spread it ... they must do some other conditioning, because rocks don't pop up by the zillion out of northern latitude courses, even after decades of existence ...
use a few screens and recycle and you can get it as fine as you'd like ... the stuff is rentable, because course architects sure don't own and trailer them around the countryside ... perhaps if there's an off-season rate it could make sense for the farm ... [golf course architects/shapers would know where to find them, and the expected rates]
won't work for an acre or two, but probably worth the while for a larger area ...
Of course, 5-gal buckets have their own charms, but I've never been able to find the 5 willing gals!
John
/ rock removal ideas? #46
My tractor tires used to be wet on bottom sides, but that stopped when the neighbors dogs were broke of that habit. At least they got cleaned off.
Have windrowed rock with a landscape rake, seemed like the faster you could go the better they were pulled and tossed out to the side. The downside was in a rough field after a couple hours it took several barley pops to find the kidney i thought i had lost. Sometimes can just windrow them over to the nearest fence line and 'temporarily' park them there.
The field was the leftover from a glacier (moraines). Guess the ice did not want all the rocks either.
/ rock removal ideas? #47
There is a machine out on the market now that can and will clear your field for you. Screens material down to 3/8s minus if you would like.
Website: ridoroc.com
/ rock removal ideas? #48
They aren't cheap, but I believe the most efficient way to clear lots of rocks is with a skeleton bucket. Skeleton Buckets
These are quite common in Holland, used in demolition. Used on excavators as well as loaders. The problem is that when you shake the bucket to let the dirt fall out, often the rocks bounce out too. A better way to sieve material is a rotating mill, but those arent suitable to demolish things because they're not strong enough. Mostly the skeleton bucket is used for large parts, and the actual demolition, then the rotating variants are used for final site cleanup.
This remembers me of a machine invented by an irishman, pictured in a paper a few years ago. The guy grew potatoes on rocky ground. He used a machine like this, which was based on an existing potato digger: It used an excavating conveyor that dumps material on a screen, to put the large particles (rocks, weeds) under the dirt.
The dirt that fell through the digging conveyor, was catched by a rubber conveyor to be placed on top.
Also, a few months ago someone posted pics of a similar design in the "build it yourself" section of this website.
/ rock removal ideas? #49
Hey Guys, interestingly, this is my very first post to TBN. I have been like a sponge, absorbing so much awesome information on the various threads I have read.
Rocks are something my wife and I deal with on our 20 acre spread. I think we have close to 70 rock jacks on our place (averaging 36" in diameter) which we use for fencing issues.
On the topic of collecting small rocks......... Either Susan or I drive the tractor, while the other one scoops up those smaller rocks with what I will call a pitch fork (but with a lot more teeth on it), and tosses them into FEL.
In either case, drivin' or scoopin' I have my mp3 player on - listening to jazz or blues in the process.
My newest threat to society is a 240 volt mig welder, to go along with a used stick welder I got last year. I welded 25-30 years ago and am trying to get some of that skill back. Yes, I can weld. No, I am not a welder.......
Anyway, I have now made my first post. The stress is off......... again, an awesome group of people here.
Chuck
Klamath Falls, Oregon
/ rock removal ideas? #50
After I saw the post I made, under my name, picture, I noticed it says I have 7 previous posts. I wonder what kind of monkey juice I was on when I wrote those because I sure don't remember them. Oh, well!
My wife and I have a small flock of colored wool sheep. I like sheep as a source to keep grasses down, as a fire protection. Susan washes, spins, and works with the wool.............. We have had as many as 40 grass maggots, but we are down to 2 right now because I am redoing fences and pastures.
Have you ever needed to say you "knew someone who ________" you fill in the blank? Well, you can now say that you "know someone who owned Raymond Burr's (Perry Mason/Ironside) prize colored ram".
So that I don't get gigged for gettin' off topic, if Home Depot ever decides to market rock jacks, I can undercut any price they want to advertise - I have that many rock jacks "in waiting".
Chuck
Klamath Falls
/ rock removal ideas? #51
For you people that are looking to get rid of rocks what ever size they are. There is a machine out there that does pick up all the debris you would want to get rid of. This machine leaves sand behind creating perfect arena footing or base material needed for horses or farm land.
Check it out at Ridorock.com
/ rock removal ideas? #52
we used the bucket method, take one 5 gallon bucket, fill with rocks, take bucket dump bucket on wagon, when wagon is full take shovel and scoop out rocks til empty. thats a low tech way and cheapest way to do it. but thats a sweaty and back breaking way to do it. when i was a kid i had 3 sisters and 2 brothers and there were always rocks to pick up after spring plowing and thats how we did it, and used the rocks for road beds, filled gullies, and fill. but i sworn i'd never pick up those #$% rocks when i grew up and i never have. there are rock pickers out there and if you got the bucks buy one, other wise, get yourself a nice bucket.
/ rock removal ideas? #54
... before the sand footing is put down the rocks have to be picked up. I tried windrowing with a york rake with limited success as I didn't want too much down pressure since that would dig into the surface and we want to keep it compacted...
Try a rock hound attachment for a skid steer. Call your local rental yard to check pricing.
/ rock removal ideas? #55
Where we live it " rains rocks " and they grow really fast. The best method I have found is to pick them up by hand. Now that I have the FEL I can fill it up and dump them in to a sink hole.
/ rock removal ideas? #56
A good tool for picking up smaller rocks (anything beats bending over!) is a bedding fork. The tines have a spacing of about an inch or less IIRC.
image.php
/ rock removal ideas? #57
I had a custom bucket made with 1" perforated steel. It sorta of become a Rock colander.
It works amazing. When I take anything to the land fill they charge by the pound. As I was always doing clean up the bucket would always scoop up some sand along with the rock/debris. Now I scoop it up with the perforated bucket and the sand falls through only leaving the debris.
They have rock buckets you can get or you can also get an old bucket and cut enough doles in it to do the same thing.
/ rock removal ideas? #58
Wow, this thread was started 10 1/2 years ago.………and people are still using the bucket method. Glad we don't have rocky pastures here!!
/ rock removal ideas? #59
Hi, I own a rock removal business called "Arena Rock Doc." I specialize in removing rock the size of cantalope down to 3/8's of an inch. I have a special rock screener that I pull behind my tractor. Check out my website for a better discription, pictures and video. Home Page
Thanks, Pete
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2017 Mack Semi (A64047)
2017 Mack Semi...
