Rock Show!
   / Rock Show! #11
ONE HUNDRED FIFTY TONS...sling-shot heaven /forums/images/graemlins/grin.gif
Question on the fabric: I plan on a gravel drive to my pole barn. Part of the drive would go across a section of my back yard. If I used the fabric would I need to grade out a few inches of top soil first or could I lay the fabric down and put the gravel on without grading?
I currently drive across it with 250 powerstroke, 16' trailer and tractor. The only time the wheels make an impression is if the ground is wet.
I have graveled part ( to the edge of the yard) already. I put down a base of crusher-run, packed it and then put washed stone on top. Just need to complete the part across the yard and pasture.
Framwithjunk I wished I lived close I would come over a FEL a few loads to help out...and have some fun /forums/images/graemlins/grin.gif
   / Rock Show!
Not being the ultimate authority on roadbuilding, I'm not too sure about cutting the topsoil away. I did in my case, for a couple reasons. One was to level the path. Second was because I needed a few buckets of dirt to fill where a tree stump was removed.
The biggest single factor in roadbuilding is D.R.A.I.N.A.G.E. If the base sits full of water, you've got problems later on.
   / Rock Show! #13
Thanks for the info Dan, so much to learn, so little time.
   / Rock Show! #14
</font><font color="blue" class="small">(
The biggest single factor in roadbuilding is D.R.A.I.N.A.G.E. If the base sits full of water, you've got problems later on. )</font>
=== <font color="red"> ************** </font> ====
Make the base of the base above the surrounding land.
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
