Roll Up Doors rattling....
   / Roll Up Doors rattling.... #11
Look at your local hardware store for the rubber lip the sell for wooden doors. They used to all be foam rubber but the brand that Home Depot carries has changed it to a more solid rubber. That might work in your favor. If you can mount it to something to push against the door (I think it will fit similar to the previously mentioned plastic strips to the door frame). It might have more springy pressure than the plastic weatherstripping. Cheap enough to try (9' or 16' strips). Or turn the radio up. Then cut some wood, grind something, start your tractor up, etc. Then you will not notice it.
OK, finally figured it out...there IS weatherstripping in the tracks that was left off by the manufacturer. Builder ordered me some and is coming out to install. They apparently exert enough pressure to keep it from rattling. Thanks all!
   / Roll Up Doors rattling.... #13
I'm sincerely glad that everything worked out positive and the problem will soon be corrected.
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A57024)
2017 Yale GLC050VX...
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
2011 Ford F450 Diesel with Just 156638 Miles (A57024)
2011 Ford F450...
