HCJtractor
Veteran Member
- Joined
- Jan 28, 2009
- Messages
- 1,519
- Location
- upstate South Carolina, Greenville
- Tractor
- Kubota M6800, Massey Ferguson 240
I am restoring an old planter. I have disassembled the coulters and removed the two roller bearings and seal, and these are still available. My question is do I also need to replace the bearing cups? They appear to be smooth and not pitted. They are obviously still seated in the cast iron hub. Do you only replace the cups when they are bad or do you do this routinely every time you replace the bearing cones? And if you do replace them, how do you get them out of the hub and how do you press them back in? I believe that I can still re-use the old ones and just leave them alone, but just wanted to make sure.
Also is there a trick to pressing in the new seals or do I just carefully tap them in, maybe using a wood block? Thanks. I have never done bearings before.
