Harv
Elite Member
- Joined
- Aug 22, 2000
- Messages
- 3,346
- Tractor
- Kubota L2500DT Standard Transmission
This one is a work in progress, but maybe I could get some opinions from the board (I've seen no shortage of opinions out there). /w3tcompact/icons/smile.gif.
In an attempt to address the ol' on-board storage problem, I've turned to the void behind the driver's seat between the ROPS uprights. Without drilling, welding or in any other way degrading the integrity of the ROPS itself, I finally came up with a way to mount a rack where it might do some good.
The rack itself is composed of angle iron and square tube. All is held together with good old-fashioned nuts and bolts, and a little rubber matting material protects the ROPS even more and provides a little traction where needed (it's always about traction, isn't it?).
A couple of 6-inch lengths of 2-inch angle iron are used to form a support bracket which can be securely clamped onto the ROPS upright, with the rubber matting serving as a cushion. With one of these brackets on each side of the ROPS, the square tubing is bolted down to form a sturdy horizontal rack (see attachment).
That's as far as I've gotten so far 'cuz I haven't decided exactly what I want to mount on the rack. Some ideas (and a little tongue-in-cheek has been used here) are depicted in these pictures.
Ideally, if I can manage it, I would make some quick-attach options so I could easily change configurations depending on the tractor project of the day.
A couple of concerns --
How will this affect visibility of the rear implement or just backing up in general (didn't think to check that out when I had the chance /w3tcompact/icons/frown.gif).
What's this talk on the board of "reaching the toplink" from the driver's seat? Not sure I understand how or when you would want to do that. I guess I'm still too much the newbie.
Comments, ideas, criticisms would be most welcome.
