ROPS thickness
   / ROPS thickness #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi, I'm now considering trying to build an rops for my yanmar. How thick is the metal on an ROPS? thanks, bw
   / ROPS thickness #2
<font color="blue">...How thick is the metal on an ROPS?...</font>
Depending on the tractor it's mounted on, it varies... but I believe the average ~~ 3/16" (7 gauge) steel...
(I'll try to measure mine later and post)
   / ROPS thickness #3
Hey Brett,
On my 226 , what should be about the same size as your tractor (about 2000 lbs) yanmar used 2 inch square tubing with quarter inch wall. The adapter plate that bolts on to the rear axle housing is made out of 3/4 inch plate. Let me know if you need pictures.
Pete
PS helpfull tip, make sure that you make the rollbar low enough, or folding, so you can get it in your garage. My rollbar was about a 1/2 inch to tall, and after the 2nd try, out came the saw and welder, now I have a couple inches to spare.
   / ROPS thickness
any pics would be great. I'm going to go for this I think. I'm not a welder but I like to do things myself and the chance to get another tool is just too tempting. thanks, brett
   / ROPS thickness #5
I'd be careful with a homade ROPS . While it might be okay for you, If you ever sell the tractor and the next owner rolls the unit, you could and probably will be sued if the next owner gets injured. ROPS manufacturers have to be approved by OSHA, the structure MUST be welded by a certified welder and the ROPS must carry a certification plate that states that it is indeed, certified. If you reall want one, I'd contact a welding shop and have one made up by them. That way, the liability rests with them as the fabricators.
   / ROPS thickness #6
Dont build a rops. Build heavy duty light bar or canopy mount...
   / ROPS thickness #7
You can build almost anything yourself, but if you later sell it, you are the manufacturer. As long as you aren't doing it repetitively, you don't need a license. On the other hand, I'd call it a canopy or light bar when sold and the buyer must acknowlege it isn't being sold with US safety features (ROPS, PTO shield etc.).
   / ROPS thickness #8
Re: ROPS thickness cab retro fit?
can someone send some pics of there roll cage retro fit's? I'm about to add a rops and a fully enclosed cab for my hinomoto.. i'm planning on mowing several acres and was going to tint the windows /forums/images/graemlins/cool.gifetc.. but i'd like to get a rops fixed while i'm doing it.. thanks..
   / ROPS thickness #9
Law and Justice when did the two paths split?
As far as homemade ROPS are concerned, if it is made at home is is not a ROPS unless you are a certified welder and mechanical engineer. Homemade ROPS should be removed from the tractor before it is sold. Even if you tell the new owner about it he is still betting his life of your workmanship. Maybe a homemade ROPS should be called a roll bar. I guess the mark should be higher for the amount of risk you are willing to accept for other people.
Chris
   / ROPS thickness #10
I agree with the Dr. I don't believe you can go wrong by hanging a running light on it and calling it a lightbar even if it does resemble a rollbar.
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
