Rotary blade replacement
   / Rotary blade replacement #11
On my Landpride RCR 1860 there is an an access hole through the top to get to the blade nut. There is a round rubber plug that has to be removed. I use a 1/2" impact gun and a socket on the blade nut. A couple of blips on the impact gun and the blades fall on the floor. You can crawl underneath and use a 15" Crescent wrench with a cheater bar and get the nuts off. The Crescent wrench method will put about a pound of dried horse poop and grass in your mouth and nostrils and you will lose a few ounces of flesh off of your knuckles. For the macho "No Pain, No Gain" guys give 'er a go with the Crescent wrench.
2024 Frontier FL1061S Hydraulic Flail Mower (A55315)
2024 Frontier...
UNUSED JCT 84" HYD 4N1 BUCKET (A57193)
UNUSED JCT 84" HYD...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
