Rotary cutter for ford 600
   / Rotary cutter for ford 600 #1
spd132
What size rotary cutter is everyone owning a 600 series ford running? Been looking or a good used cutter but don't know about a 5' or 6' for this tractor.
   / Rotary cutter for ford 600 #2
it will pull a light duty 6' er .. but i would only use it for pasture clipping or light sparse brush. a 5' on the other hand can cut just about anything the front axle can make it over. w/ a 5' I've cut 5-7' tall overgrown stemmy weeds in 1st gear, max throttle, standing on running boards to see.
howse / kk are medium duty units. the lower weight makes it easier on the hyds.. etc.
   / Rotary cutter for ford 600 #3
If you get in heavy grass with a 6' you will wish you had a 5'.:2cents:
   / Rotary cutter for ford 600 #4
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
