Rotary cutter for Ford/New Holland 3930 question
   / Rotary cutter for Ford/New Holland 3930 question #21
Put some front weights on the 3930 and you will be set. If you have the front weight bracket you will be good to go. Weights are easy to find for older Fords but not necessarily the brackets. A TN 65 should handle a 10' cutter if conditions are not too extreme. It would be at the lower end of the HP range for that size cutter. Again proper front ballast is key.
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
TRUCKING INFO (A50775)
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
(1) Drum of Algicide (A51573)
(1) Drum of...
