rarvesen
I have never owned a rotary cutter before and have some basic questions. I will be using the cutter to cut down overgrown weeds in a rocky environment in Central Texas. I'm looking into the Land Pride RCR1860 cutter and had questions on some of the options.
Driveline: shear-bolt, or 2-plate slip clutch
I'm not sure the advantage / disadvantage to each option. Is 2-plate slip clutch the better option? I expect to hit rock while mowing.
Tailwheel: laminated, or solid rubber
I don't have any experience with this. The cutter will not be used that often, when used, it will be going over rough ground with cactus and rocks.
Guarding: chain, rubber, or metal
I'm not sure which type of guarding is preferred. Would rubber most likely need to be replaced in the future?
I really appreciate any feedback. I'm going to talk to the local dealer also, but find it helpful to get opinions from here before talking to the dealer. Let me know if you have other suggestions for a rotary cutter, this will be used with a Kubota L3200 (32 HP, 25 PTO HP).
