Anyone know what size rotary cutter is best for the Ck 20s HST 4or5 foot ~one dealer said a 5 foot would work another said stay at 4feet .I am confused planing on getting a new CKS 20 HST and cutter this week ... :confused2:Thanks Jeff
I have a 4' (rotary cutter/brush hog/bush hog) that came with my CK20 when I bought it used, it does a good job though I have not used it much, use the finish mower much more.
Rancho
And a 5 footer is a little more than a 22 hp ..17at the pto should pull from what I have been told .. Each dealer tells me something different .. Thanks Jeff
I will be mostly cutting field brush no yard cutting .. I was told that I needed to get a cutter at least as wide as the back wheels of the tractor if not I would be pushing down field grass making it harder to cut .. A 4 footer would be a little short of that .. And a 5 footer is a little more than a 22 hp ..17at the pto should pull from what I have been told .. Each dealer tells me something different .. Thanks Jeff
If the cutter is wider than the tires to keep from pushing down the grass, then it would have to be a mid mount mower, cause anything you pull behind is going to be cutting what you have already driven over with both front and rear wheels..
Rancho
Thanks, To bob and everyone that replied ... Purchased the Ck20 HST yesterday .. Will be Delivered Monday .. Had the 50hr service,loader hooks added and two Kioti hats thrown in the deal for $12.600 .. Thanks for your comments it really helps ..
