ROTARY CUTTER SPEED
   / ROTARY CUTTER SPEED #11
Farmwithjunk said:
It's obvious that some folks feel very passionate about this subject. It's equally apparent that the results are varied from person to person, mower to mower and tractor to tractor.... and let's not forget grass and weeds to grass and weeds. ;)
I didn't see too much excitment on this topic...
Now, is it better to brush cut with a hydro or gears...??
That'll bring a response!
   / ROTARY CUTTER SPEED #12
Hydro or gear?
Cal/clor or Rim Gaurd?
R4's or R1's?
Which mows the best?
Answer; Which ever you have in your barn at the time.
   / ROTARY CUTTER SPEED #13
Most of my mowing is 1200 rpm. It cuts fine at that speed, I did the lawn once with the brushhog and it looked ok, except I cant get real close to the house :)
If you run into thick heavy clumped grasses you will probably have to kick it up a few and slow down some. Same if you are mowing over multiflora rose. For avg spring weeds, gear up and rmps down a little. If it looks like you need to go faster, then give her a kick.
   / ROTARY CUTTER SPEED #14
Farmwithjunk said:
Hydro or gear?
R4's or R1's?
The one and only way to mow is with a sickle-whip mower pulled by a tractor with R18 tires filled with plutonium and using a turbo-electric transmission. Anything else kills the grass and spreads rabies.
I figured that I'd inch up the rpm's till the initial vibration smooths out and try it at that speed. Not sure what that is right now, but I know it's substantially less than the 2500 rpm's I need for 540 at PTO. Should be able to save some fuel since I'm cutting grass and light weeds.
   / ROTARY CUTTER SPEED #16
I tried cutting with hydro (fluid), but it just made a mess and didn't cut anything. Then I tried a gear. It wasn't too sharp, so it didn't do much cutting either, but was a lot less messy.
I think sticking with a mower blade will be the best for my cutting needs.
jb
   / ROTARY CUTTER SPEED #17
Farmwithjunk said:
I just walked in from 3 hours of mowing. I cut for about an hour with my Massey 150 and the 6' Bush Hog 286. 540 rpm on the pto is @ 1750 engine rpm. I cut a while at that speed. I cut for a while at 1500 rpm. I cut a while @ 1400 rpm. And I'd bet NO ONE, maybe not even I could walk out in the field and tell where the slower or faster engine speed was used. Then I fired up the Deere 6430 and 15' batwing. I varied rpms as much as 800 revs from slow to fast. Same deal. You can't tell the difference..... EXCEPT..... on the fuel gauge. The Massey will run all day on aprox. 2-1/2 gallons less fuel by holding at 1500 rpm as opposed to 1750. Not sure on the Deere, as I've never really checked the "milage". The Massey has been with me for 36 years. If using it "easy" was going to hurt it, I believe it would have by now.
Back to serious posts now... I read the above last week and have to say I was skeptical, but instead of questioning it I figured I would just give it a try. I did, and got a surprise. On my tractor 540 PTO is at 2200 engine rpm. I tried 1800 and 2000 engine rpm (the lower equating to about 445 PTO) and found the results were about the same as at 540 PTO rpm. Big surprise to me. Also found out a few other things in the process:
1) I'm not getting really good cut quality on grass at any ground speed much over 3.0mph, even at 540 PTO rpm. This is a big disappointment as I sized the tractor vs. mower to allow for cutting at higher speeds (and on power alone I could cut at 6-8mph, maybe even more). I can cut various weeds and woody plants at higher speeds than 3mph with perfectly good cut quality, though.
2) This is probably old news to those with experience, but cut quality seems a lot better on really tall grass (12" or more, especially if 20" or more) than on grass that is just on the tall end of lawn grass (6-8"). I figure that the taller grass provides more resistance to being just knocked over and therefore gets cut more evenly.
3) With my setup I'm not getting good cut quality on anything when I go significantly below 1800 engine rpm. Not saying that this will hold true for everyone else's setup, but that's what I find on mine.
   / ROTARY CUTTER SPEED #18
Hydro or gears- You gotta be kidding! Gears may be OK for someone with a big flat field of grass but when you wanna cut thick or thin, up or down, its real nice to just let up on your pedal a bit to ease into things instead of trying to slip a clutch or grab a lower gear half way up a hill.
I just wish that my JD had a clutch pedal that would disconnect the PTO like my old Bota did.( It had hydro and a clutch)
   / ROTARY CUTTER SPEED #19
I just cut about 2 acres of wooded meadow and surroundings last weekend at my remote property. The grass and weeds were about 3 to 4 feet high. I checked out the blades and bolts on the 6' Howse rotary cutter before I started and also the gear oil level. Then sharpened the blades a tad and hooked it up.
Here's a picture before:
And one after I got done.
I had to cut between the trees on the perimeter of the meadow, going forward and backwards at times. I have a 55 hp gear tranny Kama 554 with 540 PTO rpm at 2300 engine rpm in the 540 PTO speed. I have 2 PTO speeds, 540 and 720 rpm.
Here's another view:
I can't go too fast because the terrain is not flat. In fact, it is my food plot, so there are several natural swells and gullies and a steep bank on one side. I mow in 2nd or 3rd low, and using 1 low reverse to cut up the steep bank.
I cut all this terrain at 1725 engine rpm with my PTO in the 720 range. That means the PTO is spinning at 540 rpm, which is perfect for my rotary cutter. This engine rpm range also just happens to fall in the engine's peak torque range (or very very close to it). So when it feels a strain, it pulls through it with very little bog down at all. Additionally, I get much better fuel economy. It took me about 4 hours to finish everything, going around the trees, gullies and banks.
To give you an idea of what it looked like when still green, check this out.
I had cut a part of it a month ago when it was still green to generate some interest for the wildlife.
IMO, there is nothing wrong with using lower rpm when mowing. In fact, I would go as far to say the lower rpm you can get away with, the better for a number of reasons. Fuel economy and wear and tear on the tractor AND your rotary cutter are a couple of them. The flip side is how fast you want to get it done , of course.
I could have used lower engine rpm on the down hill passes, but although it does not look very sloped, it is. So going uphill I needed to keep the engine rpm at a reasonable point to generate enough hp to keep her going. I would say your limiters are the kind of terrain and what you are cutting determines the hp needed, and the outcome of the cut. That is, is it desirable and acceptable to you. That in turn will tell you if the PTO rpm is correct for YOUR job.
2005 Caterpillar 242B Two Speed Compact Wheel Loader Skid Steer (A46683)
2005 Caterpillar...
More info coming soon! (A44571)
More info coming...
Trash Combo Trailer (A45336)
Trash Combo...
2025 Mini Excavator Fixed Position 3-Tooth Thumb Attachment (A45336)
2025 Mini...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
2016 Ford Explorer SUV (A46684)
2016 Ford Explorer...
