Rotary cutters - domed or flat back
   / Rotary cutters - domed or flat back #11
^ +1 That has a domed upper surface so the rain will run off and is easy to clean, and there's no pockets to hold water. It has a heavy duty tail wheel, and a curved rear deck so you can get close to what you need to. The chain guard is also the only way to go, rubber belting does not work for long.
I made inquiries of the dealers, again, this morning. Considered a cutter with 2" rather than 3" capabilities. Still a herking lot of $$$. I'm going to have to give this purchase more thought.
There are MANY advantages to living in the PNW. However, one of them is NOT freight costs.
Again - thanks to all for you input. Now I have to decide if the cost is justified.
   / Rotary cutters - domed or flat back #13
Oosik...
The smooth top cutters have the reinforced frame under the top. In my view I would prefer to have that frame on top. Easier to keep clean. Five foot may be what you are looking for but I would go as wide as my rears. I'm sure your tractor is probably around six foot or so. Just a thought.
Yup, smooth top repels rain but hides frame. If you keep it covered, or live in a relatively dry area like Amber, Washington I think a domed would do fine.
   / Rotary cutters - domed or flat back #14
I would go heavy. I have had three bush hog style rotary mowers, a six foot Land Pride, a ten foot Modern Ag and a 15 foot Woods batwing. "Things" get pretty radical, ie; rough and noisy when you are cutting heavy stuff. The Land Pride paint did not hold up too well but over the ten years that I had the mower it worked just fine. The front corners were squared off so to minimize damage from errantly catching a fence post, I welded on some steel angles that I fabbed up. I have not kept up on equipment prices but perhaps Tarter made would be less expensive and still meet your needs?
   / Rotary cutters - domed or flat back #15
Sounds like a ROAD TRIP in the Taco Wagon to me!!!
SR
   / Rotary cutters - domed or flat back #16
BTW - I would also recommend a slip clutch on a bush-hog. And be sure it's a slip clutch and not an overrunning clutch. I had one dealer that didn't know the difference and only had overrunning clutches. I made him cancel the entire order.
   / Rotary cutters - domed or flat back #17
Make sure to service that slip clutch come spring. I told my neighbor to do so when I sold him my 15ft batwing along with the 108hp Case I pulled it with. That was in the winter. Come spring he thought that he would just do a little with it until he had time to service it. Pretty much destroyed both wing shafts.
2020 Hino 195 16ft Electric Box Truck (A51692)
2020 Hino 195 16ft...
2000 Ford F-350 12FT Stakebody Flatbed Truck (A51691)
2000 Ford F-350...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2016 Suzuki King Quad 500AXI 4x4 ATV (A51694)
2016 Suzuki King...
2006 Peterbilt 379 Wet Kit Tri-Axle Day Cab Truck Tractor (A51692)
2006 Peterbilt 379...
