Rotary Cutter Rotary Cutters
   / Rotary Cutters #1
Anonymous Poster
Epic Contributor
Just wanted to pass some results of some extended research I conducted during the recent purchase of a new rotary cutter. There is nothing new here except that I wanted to emphasize some points that might be helpful for prospective rotary cutter buyers. I wanted a new 60" rotary cutter for my Kubota L3600 to deal with 1-2" brush and pasture mowing (20 acres). Based on some previous excellent advice from this website, to get a good quality cutter that would give long dependable service, recommendations were to concentrate on cutter deck thickness, cutter overall weight, gear box HP rating, blade tip speed, slip clutch, safety chain protection, and blade size.
I looked at many brands/prices through the internet and visited multiple dealers in my western Washington state location. It became quickly evident that it would be a good idea to stick with the better known quality brands (Bush Hog, Land Pride, Woods, John Deere, etc.). It was also interesting to note that no matter the brand of a good quality cutter, the price would be about $800-1000 for a light duty cutter and about double that for a medium/heavy duty unit, $1800-2000. Most of the quality brands all had about the same specs and same options. It was also obvious that I would need to go with a medium/heavy duty to get the features I wanted. I finally opted for a Land Pride RCR 2560 for an overall cost of about $1900. It had 10 guage deck thickness, 1/4" side plates, slip clutch, 100 HP heavy duty gear box, 4" cutting blades, front/rear chain guards, replaceable full length skids, heavy duty stump jumper, laminated/adjustable tail wheel, and weighed at the top end of recommended weight limit for the L3600 (800-900 lbs).
The price was almost a show stopper but after using the cutter for the last month, it has certaintly proved the right choice. I mow in very rocky soil and sometimes hit rocks from mole hills and around brush stumps. The medium/heavy duty cutter takes this in stride and I find that I mow in less time due to cleaner/more complete cutting on the first run. As they say, you get what you pay for.
   / Rotary Cutters #2
Mark, I've got the same mower with an L3710HST. I'm interested in how it performed cutting the 1-2" brush/trees. I've been a little hesitant to tackle such big stuff.
Joe
   / Rotary Cutters #3
Mark,
Congratulations on getting a great cutter. It is amazing what a difference a really heavy duty piece of equipment can make (aside from the dent in the wallet!).
Best of luck with your new toy ...er equipment!
John Bud
   / Rotary Cutters
Joe-
I've used the RCR 2560 mostly on pasture mowing and some 1" brush since purchased last month. I normally slow down with thick grass for a cleaner cut and for brush work. I am also careful not to damage the rear chain guard if backing into thick brush.
I've noticed that I will drop about 100 rpm on heavy grass (3' high) and about the same on the brush I've cut so far. I have a loader and if attempting to cut heavy brush, I normally push the brush down with the loader and slowly run the cutter over it. This makes the cutting more controlled and also prevents bending the chain guard holders. The tractor has handled it fine. Since we basically have the same exact tractor, I don't feel you will have problems. The tractor is rated to handle this size mower and the mower is rated to handle at least 2" brush. Good cutting.
   / Rotary Cutters #5
What advice can anyone offer on the Howes brand of cutter? The offer an "economy" cutter...I'm looking at a 4' cutter for a JD 4200. Been quoted a price of $475 for a new unit.
   / Rotary Cutters #6
With your size of tractor I would get a 5ft. cutter. Cost will be about the same. I picked up a used 5 ft.Howse light duty cutter 2 years ago for $175.00 that was only about 6 months old, but abused to no end. They backed it into large trees trying to use it like a heavy duty one. I needed to replace one skid and straighten the sides back out on it. I took it all apart and reinforced it and it works great for what I use it for. Mostly cutting grass, but have used it to take down some thick stuff with no problems.
   / Rotary Cutters #7
Nearly two years ago, I bought a new Howse 500 (5') for $495. Sounds like the same mower. Not nearly the quality of the Bush Hog I'd had before, but a lot cheaper and is quite adequate for my use.
Bird
   / Rotary Cutters #8
Thanks for the quick response. I don't plan to use it often, and then only for fairly light brush...maintaining a trail path. I think I might just keep my eyes open a bit longer for a used one, or even possibly a different brand.
   / Rotary Cutters #9
Inconsistant quality control problems...
My 4' unit, but I would pay a few dollars more for a KingKutter version.
"You are what you eat, drink, think, say and do..."
   / Rotary Cutters #10
I was also looking for a quality rotary cutter. I found a brown 460 for $850. It has a 7 ga deck 1/4 x 2 slides (replacable)
a 90 hp box, stump jumper, slip clutch 4" blades round back
found it at North Ga tractor in cornelia, ga
   / Rotary Cutters
Howse is meant to be cheap. I have a Howse MH5 (5' medium heavy cutter w/ 10 ga. deck, 100 hp gearbox) that I got for $650 at CT. Not nearly as nice as a Bush Hog or Woods. The gear box had a mixture of oil and water in it when I got it, and the paint job stinks. Other than that I have had no problems with it. I try not to cut anything bigger than 1-1/2" thick with it, but it has gone through a few rocks, etc.
   / Rotary Cutters #12
I also have a Howse 4 ft it was considerable cheaper than the woods but I only use it at most once a month on 3 acres, so far I have had no problems my lot is very hilly, rocky, with lots of underbrush, and it has performed very well. Probably a good low cost alternative.
   / Rotary Cutters #13
Brand New John Deere 513 in foreground with a one year old used 513 in the rear...
   / Rotary Cutters #14
Closeup of Thin Steel Used JD513...
   / Rotary Cutters #15
Rear view of Used JD513 - 1 year old?...
   / Rotary Cutters #16
Ford 30-35 year old rotary cutter... it's so rusty, you can't see the blue paint...the rear tire is worn to the steel rim & one rust through on top of deck... however... this is still usable after about 30 years of use...
   / Rotary Cutters #17
One would think that a Deere dealer would be embarrassed to display such a piece of used equipment. He might get a few bucks for it, but you'd think he'd be concerned about losing sales on his wildly-overpriced new 513's.
Immutable tractor law: the thickness of the steel on a JD light duty cutter is inversely proportional to the thickness of the profit margin on the cutter.
<P ID="edit"><FONT SIZE=-1>Edited by glennmac on 08/07/01 10:45 PM (server time).</FONT></P>
   / Rotary Cutters #18
I don't know who makes the JD513 but my Rhino light-duty unit seems a whole lot better built. For one thing, instead of that angle iron running across the top of the deck, mine has thick 4" or so channel iron. My deck material is very rigid, does not flex at all, or have any ripples in it. I do have a dent or two on the sides where I hit logs or something, but otherwise it looks good at 2 years old. I've cut down lots of 1" brush and saplings (no rocks) and thick growth and have been extremely pleased with it. My only complaint is that bolts holding the guard on the gearbox sheered off, the guard fell off, and I ran over it. I paid about $50 for a new one about a year ago and never did put it on.
The Rhino 5' was about $800 I think. I also have a Rhino finish mower and I'm very pleased with it as well.
Alan L., TX
   / Rotary Cutters #20
John,
What in the world was JD thinking when they had these 513 rotary cutters made?Don't the people who manufacture these implements for JD have to meet a certain specification? Aren't they tested for durability etc? I think JD was asleep at the wheel when they introduced these 513's!! Why would JD even let this junk get to the dealer lots? What do you think John?
I am just curious as what they were thinking.
2019 FORD F150 STX CREW CAB TRUCK (A59823)
2019 FORD F150 STX...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
