Rotary cutting pics
   / Rotary cutting pics #121
Three or four more days to go.
   / Rotary cutting pics #122
Nice.. let's you get into the "zen" mowing routine. I like wide open spaces for cutting, not so much backing and constant turns. Just mowed 15 acres here, usually takes about 7 hours with a 5 foot cutter.
Sean
   / Rotary cutting pics #123
Sean
You must really be moving or the grass must not be that high...I mow about 15 acres and it usually takes me about 12 hours but it is about 3 to 4 feet high when I cut and I use a 5 foot bush hog as well.
   / Rotary cutting pics #124
The grass isn't that dense in most places, weedy though. I usually mow that field in 1-high, just fast enough to get a decent cut and not get shaken to death.
Sean
   / Rotary cutting pics #125
Sean, that explains it ..mine it really thick in quite a few areas, about 5 acres of it are thick - really thick and I cut in 3rd gear and #2 speed. I will be posting my pics in a few weeks since I have to tackle it soon..
   / Rotary cutting pics #126
Sean
Actually on that farm, we have a mix of open and really tight places that I have to creep through watching the cab clearance as well as the trailing pull type 10'6" cutter. We also have some ponds to mow around, so those open spaces sure are a pleasant change.
   / Rotary cutting pics #129
Getting in some seat time! :D
   / Rotary cutting pics #130
2014 JOHN DEERE 4066R LOT NUMBER 23 (A53084)
2014 JOHN DEERE...
2003 International 4200 Box Truck (A51692)
2003 International...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
