rotary mower vs. finish mower
   / rotary mower vs. finish mower #11
I think WOODS makes a 90 inch rotary cutter finish-type mower that can be used for meadows and pastures. It is like a cross of a rotary cutter and finish mower. There a re 3 blades that pivot on a dish like a rotary cutter in case you hit obstructions. Look up this mower under WOODS website. It may be listed as a finish mower but may be a good compromise for you. You would probably need a larger tractor (30HP? or more) to run it.
   / rotary mower vs. finish mower #12
Good choice. Keep in mind replacement parts such as blades etc. I personally like to buy equipment from the local dealer for that reason. (only have JD locally). I recently purchased a JD HX-10 to go behind a Ford 7740 although the dealer also sells Bushog, Woods, etc. Parts for the other makes would not be a problem to get but he stocks most parts for the JD including gearboxes. Just food for thought.
P.S. Believe it or not the JD rotary cutter was cheaper than any of the other comparable brands.
   / rotary mower vs. finish mower #13
</font><font color="blue" class="small">( Believe it or not the JD rotary cutter was cheaper than any of the other comparable brands )</font>
I believe it, for the JD rotary mowers aren't in the same league as they are in tractors. Rhino, Bushhog, Landpride, and probably even Woods mowers are better than a JD mower. Hence the cheaper price.
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2020 DRAGON ESP...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
