Rotella HD Tractor and Transmission in kioti hydro?
   / Rotella HD Tractor and Transmission in kioti hydro? #11
Lol, that's laughable, 424 is specifically named in the manual as an approved fluid, it's used in hydrostatic drives in construction fleets without issue, I'm not looking for a "use manufacturer oil" lecture, I'm asking about a specific brand and for info from people who know about it
Why come here and ask the question since you know the answer?Just curious ?? Love folks who buy expensive tractors then want to cheap out for filters and fluids.Laffin.
   / Rotella HD Tractor and Transmission in kioti hydro? #12
And here I am using an even higher priced fluid for it's winter characteristics and better performance in hot and cold weather.
Cen-Pe-Co multi purpose.
As my starter didn't have enough power to crank over my power shuttle in the winter.
LOU... I deal with the same cold weather in the winter as you do, maybe a bit colder and the Rotella Hydraulic fluid (Donax) flows as good as my Chevron THC that is my other tractor. I was pretty impressed.... At basically 1/2 the price of the Chevron.
   / Rotella HD Tractor and Transmission in kioti hydro? #13
Why come here and ask the question then since you know the answer?Just curious ?? Love folks who buy expensive tractors then want to cheap out for filters and fluids.Laffin.
AGREED !!!!
   / Rotella HD Tractor and Transmission in kioti hydro? #14
Many companies gouge customers on the consumables. They get someone else to make it and then sell it at a huge markup. The same stuff may be 1/2 the price of the branded items.
   / Rotella HD Tractor and Transmission in kioti hydro? #15
Well fellas I just went to the local Kubota dealer and bought 12 gallons of UDT.
Could have ordered Mobile 424 from NAPA but didn't want to wait two days. I had a mess on the floor and oil pans full of old fluid.
This topic seems to be a favorite to overthink.....speaking of......got my BlackStone lab analysis of the NAPA hyd. synthetic fluid and said it was good for another 400 hours.
Then the fun began. Removed the hydraulic filter and dumped five gallons trying to coat the floor with it, as the filter was removed and the new one installed.
That was when I said why mix five gallons of old with new. So went to dealer and got 12 gallons. Done and done.......
So at least till it hits 1k hours. I've learned that it seems each Kioti dealer uses their own local vendor for the fluid.
So look at the specs and get what ya likes and enjoy the tractor.....:thumbsup:
   / Rotella HD Tractor and Transmission in kioti hydro? #16
Nice thing about hydraulic fluid is it cleans up pretty easy with water and some detergent. I use ZEP and my pressure washer. Makes my messes vanish quickly. Used to use Purple Power from TSC but Zep works better and leaves no residue.
   / Rotella HD Tractor and Transmission in kioti hydro? #17
Ah GrassHoppah.......how did you know that was on ma mind....?????:thumbsup::D
So now after test drive will go shopping for some ZEP..........:thumbsup: & when it hits 101+ out there...this...:drink:
   / Rotella HD Tractor and Transmission in kioti hydro? #19
Because I'm not paying out the *** for tractor fluid when there's equivalents and better for less money and I'm already paying for a 140 dollar hydro filter which is nuts. Not looking for a lecture, asking a simple question
IF you feel comfortable with NAPA Gold filters they can cross reference your part numbers.
I went to WIX website and got my numbers. NAPA cross referenced the Wix numbers to NAPA, ordered them and paid 139 for both.
Course it's all about one's comfort level.
I share this not to create a which filter is better, but to offer an alternate solution.
So hope it doesn't get hijacked.
   / Rotella HD Tractor and Transmission in kioti hydro? #20
Not sure why people are referring to Shell Rotella HD as "cheap."
Folks have no complaints on running cheaper stuff, stuff like Travelers.
I went with Rotella after cross-checking it (a major on-line retailer crossed the Mobile 424 to this). My dealer replaced "Kioti" hydraulic fluid with "Mahindra." Hard-pressed to think that these two fluids are better than Shell.
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
VERMEER RTX250 WALK BEHIND TRENCHER (A52705)
VERMEER RTX250...
8ft. x 35in. White Metal Roof/ Wall Panel (A55758)
8ft. x 35in. White...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
