Pilot
Veteran Member
- Joined
- Nov 20, 2004
- Messages
- 1,208
- Location
- Oregon
- Tractor
- JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Our little country church (about 60 members) has a pastor's residence next door, built around 1904. Hasn't been used by a pastor for 15 years. When the latest renters moved out, a member came up with $6,000 to have the place painted inside and out.
Painters found all the siding on the west side is rotten. Punched thru the siding in one area to find another layer of a different kind of siding behind the outer layer. It has different siding in different areas, so some of the rotten siding may not have a second layer behind it. Not knowing what else to do, they painted it.
What we need to know now, is whether the framing might be wet also. Is there a good, easy way to check without pulling off the siding or pulling sheetrock? My guess would be to use a hole cutter to cut several 2" holes in the sheetrock, then patch it up again. Is there a better way?
Not relevant, but just to add to the story, when the painters were working, a water line came apart at a poorly glued joint in the PVC pipe and ran for about an hour before the painters could find a place to shut it off. Turns out, someone used glue for CPVC pipe on PVC pipe. They used the right glue in most spots but maybe ran out and switched to what they had left over from running the CPVC line. The plumber was able to pull some joints apart with his pliers.
