Rotten Stump Removal "Yeah Right"
   / Rotten Stump Removal "Yeah Right" #11
About 6 years ago I eyeballed a medium size black locust growing in "neck" of land sticking out into a farmers field causing a very awkward corner. I pointed out that if I removed the tree his brother who owned a gravel pit with backhoes, etc. could remove the stump and make his farming easier - done deal. Except. By the time they had the stump down to where they were satisfied they could have buried the backhoe in the hole.
Harry K
   / Rotten Stump Removal "Yeah Right" #12
Some stumps can really be a pain. About 10 years ago I cut a large cottonwood type tree down. For three years I tried to burn it out. Drilled holes, filled it with diesel, even took a 5 gal metal bucket and filled it with old motor oil and punched a small hole in it and it burnt for two days. It was a tree that just held water and would never dry out and burn. It was 4 1/2 ' across. I had a large backhoe and worked two days trying to dig it out, I was down about 12 ft. Rooting around and trying to cut all the roots, had a hole deep enough and large enough that you could have put a dozer down in there. I had finally dug deep enough and wide enough that I flipped it loose. It was so heavy I couldn't pick it up with a chain and the bucket. I finally dug a slope and tried to rake it out with the backhoe. I would just about get it to the top then it would tilt and fall back down. Even bent the bucket. Couldn't drag it out. Finally got it rolled to the top of the ground and as I rolled it for the last time it flipped over and one of the roots was so long it rolled toward the backhoe and smashed the rear window out. I finally drug it to the back of the property and every year I gather up all the limbs, pallets, scrap wood, I would saturate the stump with about 10 gal of motor oil and set it on fire. It took me about 7 years to get to burn up. That was one expensive stump to remove. I would have just called a stump grinding co. but where it was, I had to put a drive there and heavy eqpt. would be going over it and it would just rot and sink a little more every year, and I didn't want that.
   / Rotten Stump Removal "Yeah Right" #14
I've said it before. You build something out of wood and it rots before you know what happened (like a deck!). But cut a stump off at ground level and it will stay firm, good as new, and haunt your grass cutting efforts for seemingly ever!
   / Rotten Stump Removal "Yeah Right" #16
The only problem with that is that it is for a certain size of stump only. Actually, quite a small one! The stump usually gets quite large at ground level and you need to grind all that down to make the ground level.
   / Rotten Stump Removal "Yeah Right" #17
I have cedar stumps in my front yard that where here when I moved in and I suspect they were cut when the house was built in 1992. They are as good as the day they were grown. I try them every once in a while with the bucket, but they are solid. They are at ground level, so I can mow over them, so they are not really a problem.. I suspect they will be fine when I am dead and gone.
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
