Rough Pasture, How to make it smooth
   / Rough Pasture, How to make it smooth #1
FL_Cracker
Platinum Member
Palm City, FL & Blue Ridge, GA & Freedom, WY
Kubota L5030HST,R4 & Kubota RTV900R Utility Vehicle
I have about 7 acres that was cleared about 3 years ago. It was roughed in by a bull dozer and I grassed it myself. I did only a fair job on the grass and the weeds moved in quick because I have been only cutting it a few times each summer. It has also become somewhat rough because of the rains and other weather events. There is a lot of grass in it but also lots of weeds.
Do I have to start over and till in all the weeds or can I start adding new grass over seeded into the pasture and keep mowing to improve the overall grass bed.
What can I do about the rough spots. It's just very bumpy and I would like to find an easy way to smooth it out with out starting over.....
Any ideas.
Thanks,
   / Rough Pasture, How to make it smooth #2
I have about 15 acres that I've rutted up bush-hogging when it was too wet that's pretty rough. I'm thinking of running the tiller through the rough spots at a fairly shallow depth and maybe backdragging with the boxblade.
   / Rough Pasture, How to make it smooth #3
Try doing a web search for an implement called a "pasture renovator". (One good brand is a "Marcum" (sp) Also, consider a (heavy) roller.
I'd guess a lot depends on HOW ROUGH your "rough pasture "realy is.....
   / Rough Pasture, How to make it smooth #4
I'd suggest looking at a Harley rake, or equivalent. I had a neighbors' contractor let his concrete trucks and other big trucks run loose in my field, which I was in the process of turning into lawn. The deep ruts stayed there, and I couldn't roll them out with a 'heavy' roller. So I rented a Harley rake and even though there was already pretty good sod, the power rake did a good job of knocking off the high spots and filling in the low spots. It didn't seem to harm the grass as much as one would think. I did put some seed down, but think I could have gotten by without it.
If you can find one to rent, that would be the best to try it out. Otherwise, a tiller and start over with grass seed.
   / Rough Pasture, How to make it smooth #5
Yup, the Harley rake is a truly marvelous piece of equipment. I have a tiller and tillers do well, BUT they fluff so much and then it can settle unevenly and rut up if you are on it before it settles.
   / Rough Pasture, How to make it smooth #6
I know what you mean about using the tiller. I did that in the barn lot, now it is a low spot and just as rough as before.
2012 John Deere Z925A 60in Zero Turn Commercial Mower (A52377)
2012 John Deere...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
RIGID TOOLBOX (A52472)
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
