Round Bale Size - What do people have their set at?
   / Round Bale Size - What do people have their set at? #11
Yeah, I have a Case IH RBX563 and obviously the linkage to the size adjuster could be adjusted, because I should be able to gain six inches.
   / Round Bale Size - What do people have their set at? #12
In Europe, all round bale silage is made with fixed chamber (soft core) balers: Mostly Welger and Krone balers, with a 130cm (51 inch) diameter.
Bigger round balers were used in straw sometimes, but most straw comes in big squares.
In Finland they bale silage after 6 hours of sun on the mower swath (no tedding and raking) and they weigh up to a ton each. In Holland the silage is much drier, about 350 to 500kg for a round bale.
   / Round Bale Size - What do people have their set at? #13
When I was working for a neighbor cutting and baling hay; both his own and for other people, he had a Gehl baler that made 5' wide bales and an older 85 hp Oliver tractor. By far the majority of what we did was 5 x 5 bales, but we did some 5 x 6 for some customers who wanted them; charged them a couple of dollars more per bale. I'm not sure of exactly what either of them weighed, but I can tell you that the 5 x 6 bales were considerably heavier. He did not want bales that big for his own use.
   / Round Bale Size - What do people have their set at? #14
If you use your baler to make its maximum bale size, you are more likely to strain its bearings and stretch its belts. And a big bale can be harder on a loader. So I guess I can live with a smaller-than-maximum-size bale even if it means more bales to haul. And the bale density isn't set very high either.
Actually, this philosophy I use on my Case IH/New Holland baler is somewhat opposite of the philosophy used on the Vermeer I had before. But I am getting older and getting tired of unnecessary mechanic work and bales which are hard to feed.
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
