Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
Can anyone explain to me why a BX2200 / BX22 is rated at 22.0 gross HP and 16.7 PTO horsepower at 3200 RPM, but the rear PTO is 540 RPM at an engine RPM of 3068 and the mid PTO is 2500 at an engine RPM of 3125?
Is this typical of tractors in general?
Assuming that the 22.0 HP rating represents peak output, why wouldn't the PTOs be geared so as to operate at their standard nominal speed at the same peak?
Everything else being equal, it appears that running the engine at 3200 RPM for peak power would give a rear PTO speed of 518 RPM- only 5% slow, but why?
What is even more interesting is that looking at the specs ( Kubota Engine Performance ) and torque curves ( D905-E Torque Curve ) for what appears to be the same engine, that 3200 doesn't match either the high speed rating (with an exta 1.5HP) or the standard rating (down a couple of HP). But it does appear that the 22.0 HP rating is had at about the 3068 RPM specified for a 540 RPM PTO!
Realizing that raw engine specs do not necesarilly reflect an engine's performance in a given application, and that the various ways of measuring engine output, or even horsepower, is a significant topic in and of itself, is there a simple explaination for any of this?
Thank you...
Thank you...
