RTV 900 1 million $ question
   / RTV 900 1 million $ question
Jason537 said:
That utility valve you have it for low flow demand hydraulic like a quick attach blade, sweeper or hydraulic bed dump.
You aren't missing pieces,.. that is how that unit comes.
I was beliving my RTV was equip with this valve because I have the set of valvle for the bed lift and another set beside equip with another lever in the cab to operate it. The other RTV I saw was not equip with this second lever and set of valve?
   / RTV 900 1 million $ question #12
Thats so you don't have to swap back and forth,.. like I mentioned they are for bed lift, front quick attach implements,.. like blade with hydraulic angle.
   / RTV 900 1 million $ question #13
The plastic tank is not very good when hyd oil gets hot, so I am think that is what the metal tank is for.
   / RTV 900 1 million $ question #14
That is the oil reservoir for the work site model. It is used for the increase oil volume that is required when using hydraulic tools such has concrete saws, chain saws, and post drivers......
   / RTV 900 1 million $ question #15
Close...that's a Turf/Utility model with heavy duty work site tires and the larger hydraulic oil tank is more for oil cooling than volume.
   / RTV 900 1 million $ question #16
No I am pretty sure the oil volume is just as important as the cooling, because when you increase the volume of the oil supply it will aid in cooling as well. Also the power tools require a larger oil supply than the hydraulics put out for the bed. Then you will have the additional volume that the hydraulic hoses will contain/need and what the power tools require. Which for some people could be 50ft of hose.
   / RTV 900 1 million $ question #17
The original turf hydraulic tank was 1/2 the size of the current tank, and it still had enough volume to power all the low pressure hydraulic tools but it had heat issues. Hence the oil cooling system you see on it now, which works rather well. Yeah, the volume will help if someone goes with a 50+ foot hose but that is not the standard hose for these tools. The volume increase is more for cooling than anything else.
   / RTV 900 1 million $ question #18
Can somebody 'splain the hydraulic saw to me?
just looks like a bad idea.
   / RTV 900 1 million $ question #19
Its a saw with a hyd motor and a lever for a trigger, oil is just diverted through the motor when the lever is pulled,.. and when not, oil is cycled back to tank.
HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
HITACHI ZAXIS...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
LOOK! (A53342)
LOOK! (A53342)
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
