Take a look at UMHW.
UHMW is a heavy-duty, high-impact plastic used in a variety of extreme weather applications from forestry equipment to snowmobile skis. UHMW is virtually unbreakable, significantly more wear-resistant than steel, and not adversely affected by freezing winter temperatures. In snow plow edge applications, UHMW is much quieter than steel and more gentle on surfaces, increasing the longevity of roads and protecting aesthetic surfaces such as cobblestone and driveway transitions. Interstate Plastics cuts UHMW sheet to your specified dimensions and the material's desirable machining properties allow customers to drill bolt-holes and mount edges with ease (and with no specialized hardware required).
Our most popular plastics for UHMW snow plow and scraper edge applications include UHMW reprocessed sheet as a cost-effective solution, and IPX 2000 UHMW advanced wear technology sheet for lower friction, improved abrasion resistance, and UV stabilization.
UHMW is the perfect winter solution for applications including:
Scraper edges
Vat scrapers
Bucket lips
Skid shoes & skid plates
Skid loaders & skidsteers
Runners & running Boards
Plow blades & wings
UHMW Overview
Known for an extremely high molecular weight, UHMW features an unsurpassed combination of slickness, toughness and chemical resistance.
UHMW's molecular weight ranges from 3.1 million to 100 million grams per mole, with an abrasion resistance that continues to improve as molecular weight increases.
UHMW plastic is ideal for reducing wear and friction due to its specialized internal lubrication, reducing maintenance costs and energy consumption while extending equipment life. High durability, low friction and wear resistance are key reasons why UHMW is the material of choice for many applications.
UHMW is easy to machine with common woodworking tools, making it extremely cost effective, and outperforms metal in many applications. UHMW can be machined into virtually anything from small gears and bearings to huge sprockets. UHMW is also moisture repulsive and easy to fabricate.
Reprocessed grades, enhanced bearing and wear grades and FDA compliant grades are available for greatly extended part life. Interstate Plastics is proud to carry four specialized grades of UHMW: reprocessed, anti-static, IPX 2000 and Tivar® 88.
[UHMW Spec Sheet PDF]
• Odorless, tasteless and nontoxic
• Highly resistant to corrosive chemicals (except oxidizing acids)
• Extremely low moisture absorption
• Low coefficient of friction
• Self-lubricating
• Highly resistant to wear and abrasion
• Easy to fabricate and machine with common shop and woodworking tools
• Extends equipment life
• Reduced maintenance costs and energy consumptio
